Question about HP DesignJet 1050c plus InkJet Printer
Scaling drawings automatically HP8100
When plotting a scaled drawing from AutoCAD, the HP8100 scales the drawing minimally but enough that jeporadizes the drawing integrity
  • 72 Answers
Check the printer settings and make sure to set the "Fit To Page" option to "None".
Posted on Jun 16, 2009
Delonghi Magnifica taking a long time to heat. Is now 3 years old. regularly cleaned and de-scaled.
Hi sounds like the heating element is burning outand only drawing minimal power. There is a thermostat on the boiler which could be a fault, but it usually blows and the machine wont heat. Dazza REPAIRER
Sep 23, 2011 | DeLonghi Caffe Nabucco BCO70...
Is like this:i draft my house plan.but when print out my comes out small.what might be the problem?i used scale of 1;100.paper i used A1 size.and details i used this correct.i never had...
I believe when you used the scale of 1:100, it formatted it for the A1 paper, but only 1/100th of the size. Try doing a 1:1 (or, if available, auto) scale. AutoCAD should handle the rest.
May 03, 2011 | Computers & Internet
There used to be enough steam to froth milk for 2 cups of coffee, now I have to turn the knob off, to let the machine build up steam 3 times too get enough froth for 1 cup of coffee.
This a
clear problem from scale builds up in the boiler. The scale layer is acting as
an insulation layer which is reducing the efficiency of the heating element to
the boiler and also reducing the water capacity thus also the steam production
So you
should first try to de-scale your machine three four times with intervals of
three days from each de-scale. Try also to perform the de-scale very slowly
like when you will flash the water solution from the water reservoir take about
30 minutes why drawing a coffee cup every five minutes. With this way you have
very good chance to remove a lot of scale and you machine heating efficiency to
be increased. If after the above procedure you have no difference then you need
a new boiler which is one unit with elements and sensor.
Here below we
have a link with more information for your machine which can help you.
Dec 23, 2010 | Saeco Magic De Luxe Espresso Machine
I need to calculate the number of 55 gallon drums that can be placed in a containment pool that measures 8 ft in diameter, and 2 ft. in height. The containment vessel has to hold 110% of the material in...
Calculate the volume of one 55 gallon drum by using this formula
22/7 X Radius squared X hight of cylinder = Volume of large vessel.
22/7 X 48" (Squared) X 24" = Volume in cu in
100.57 cu ft in large pool = 752.315 US gals.
110% of 50 gals = 60.50 gals
752.315 divided by 60.5 = 12.43 drums
Draw to scale the large poola nd then draw to scale the smaller drums and see if 13 drums fit.
Feb 24, 2010 | RTO Automatic Transmission And Engine Oil...
I must create scale diagram of my kitchen on a
Convert your meters to centimeters and divide by 20. That gives you 1/20 scale
Oct 15, 2009 | Kitchen Appliances - Others
Java source code
* To change this template, choose Tools | Templates
* and open the template in the editor.
//package optimalcluster;
* @author CSEEXAM2008
import java.awt.*;
import java.awt.geom.*;
import javax.swing.*;
public class GraphingData extends JPanel {
double[] data = {
0.504782921308152, 1.174144134378306, 2.0933754535558546,6.2625807939548823,8.8484441414277364,10.0000003,12.908978000,14.8906789456,12.9087654567 };
final int PAD = 20;
protected void paintComponent(Graphics g) {
Graphics2D g2 = (Graphics2D)g;
int w = getWidth();
int h = getHeight();
// Draw ordinate.
g2.draw(new Line2D.Double(PAD, PAD, PAD, h-PAD));
// Draw abcissa.
g2.draw(new Line2D.Double(PAD, h-PAD, w-PAD, h-PAD));
double xInc = (double)(w - 2*PAD)/(data.length-1);
double scale = (double)(h - 2*PAD)/getMax();
// Mark data points.
for(int i = 0; i < data.length; i++) {
double x = PAD + i*xInc;
double y = h - PAD - scale*data[i];
g2.fill(new Ellipse2D.Double(x-2, y-2, 4, 4));
g2.fill(new Ellipse2D.Double(x-2+4, y-2+4, 4, 4));
g2.fill(new Ellipse2D.Double(x-2+6, y-2+6, 4, 4));
g2.fill(new Ellipse2D.Double(x-2+8, y-2+8, 4, 4));
private double getMax() {
double max = -Integer.MAX_VALUE;
if(data[i] > max)
max = data[i];
return max;
public static void main(String[] args) {
JFrame f = new JFrame();
f.add(new GraphingData());
Feb 07, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Incomplete plot from .pdf file - Hp DesignJet 1050C Plus
Was the plot originally done on a size D or E plotter.. A .pdf is generally not a good way to send a plot that has to be done to scale.. Can they re-send the plot in a hpgl format, or a format that you can use in another program, liks ACAD, and then print it through that program? This would provide you with some control, that a pdf document will not allow.
This is just a stab in the dark for me, but I am familiar with plotters in general, just not the many formats to print from..
Nov 19, 2008 | HP DesignJet 1050c plus InkJet Printer
Digitalizzing problem
I have a problem with the same hardware and software. I'm using AutoCAD 2008 and when I trace an object that is 1:1 it come into AutoCAD as a different scale. I have tried different scale factors in AutoCAD and nothing.
Jun 02, 2008 | GTCO CalComp Drawing Board III 34180...
HP DesignJet 1050c plus InkJet Printer Logo
89 people viewed this question
Ben Johnson
