No hot water filling washer
When using the hot cycle button, there is a buzzing noise and no water enters the machine. Yes, the hot water is turned on. I installed new braided steel hoses on both hot and cold about 2 months ago.
  • Washing Mach... Master
  • 3,463 Answers
Check to see if there is a filter located in the valve, remove and clean.
If still no hot water then disconnect hose and make sure you have actually got water at valve, if you have and it still does not come in, and you can hear a buzzing noise, then I would say that it is sticking and you have a faulty inlet valve, only solution is to replace said valve.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
Do this at your own risk !
Sounds like the water valve is blocked/ broken.
Check the filter in the valve is not blocked. This can be done at the back of the machine
Unscrew hot water hose and have a really good look with a torch.
unplug washer before taking lid off.
Take the lid off the washer, swap the hot and cold valves over and see if the fault moves to the cold fill.
Whirlpool washing machine does not rinse just a buzzing noise
The buzzing is the water valve, the timer is sending power to the valve but no water is coming out. I would set to wash and as it is filling up change the water to cold then to hot while it's filling. I bet either cold or hot will buzz (usually hot). Once you determine which (clod or hot) shut that supply off, take that water line off the washer, put the end in the washer and turn the supply back on. If water comes out then look inside the valve where the hose connects, it could be clogged. If you have water going to the valve and you don't see a clog then the problem is inside the valve...replace valve.
Oct 21, 2014 | Whirlpool Washing Machines
Machine stopped in the spin cycle, now only makes noise.
Be sure BOTH fill hoses are hooked up and TURNED ON. What happens is (commonly) hot and cold hoses are installed reversed, and no one really notices.....Then Dad gets a big hot water bill and turns off the HOT water (actually hooked up to the cold input on the machine), so when the machine gets to the rinse cycle, no water comes in, and it waits patiently (forever) for water which never comes. The buzzing is the water valve. This is the most common problem.
Dec 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
My GLTF 2940 makes a buzzing sound like a relay not pulling in all the way, during the rinse cycle. If you shut off the washer, and restart it on the rinse only cycle, it goes away.
its probably your cold water rinse only valves solenoid thats loose on the structure or the coil itself is loose,you may not hear it all the time especially during the initial wash start fill,try this, set the washer for cold water fill only on the washer,but turn off the water valves that supply water and start your machine to a wash cycle as normal,try this and see if it dry buzzes(without water),then try the same on the hot side,then with the water still off open up the machine and you can localize the buzzing noise
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Cold water is not filling machine when place on cold washer cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine is not working the way it used to--or should--check the following. Is the cold water turned on? If not, turn it on. Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct. Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
No water going to feed machine
There's no hot water Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
There's no water at allIf there's no water at all, make these checks:
  • Is there water getting to the machine?
  • Is the water-volume selector switch set properly and are the control panel buttons pressed in all the way?
  • If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown?
  • Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
  • From Repairclinic
    Oct 12, 2008 | Dishwashers
    Can't get the cold water to turn on. I have 1. switched hoses 2. no kinks 3. water is turned on Model 1220
    Aug 17, 2008 | Hoover Washing Machines
    Whirlpool LHW0050PQ - Water wont empty or fill
    This sounds like a plumbing problem. Lets see if we can isolate it. Turn the valves off behind the washer and remove them from the washer. Remove the washer drain hose from the stand pipe. Stuff one of the hoses into the now vacant drain line and turn the water on. Then do the other hose. Any noise? Now reconnect the fill hoses to the washer and reinstall the drain hose to its' place. Turn on the water valves at the wall, set the washer to a cold/cold cycle and start it up. Listen for noise. Now shut the machine off and set it for a hot/cold cycle and turn it on. Listen for noise. If you get no noise now, it's all good. If you're getting noise from just your hot water, your water heater is set too high and you have steam propagating in your plumbing. Your washer water valves (where the hoses connect to your machine) will only do this if you have low water pressure coming from the wall. Still, it'll be a plumbing problem.
    Jul 28, 2007 | Whirlpool LHW0050PQ Front Load Washer
    Washing Machines Logo
    82 people viewed this question
    Top Washing Machines Experts
