Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Chain saw cuts at an angle
When you try to cut straight down the saw wants to veer left
  • Ryan Peterman
    Ryan Peterman May 11, 2010
    What Brand/model?
  • alan_x_king May 11, 2010
    How sharp is the chain ? Does sawdust come off the log or small chips of wood
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Posted on Jul 27, 2011
    Problem Solver:
  • 16 Answers
Replace bar and chain!!!
Posted on Jan 15, 2009
Mine does this every time I hit something solid with the chain. Get it sharpened or buy the guides and sharpen it.
Posted on Mar 27, 2009
If the chain is new have it professionally sharpened if not buy a new chain and check to make sure bar is not bent most likely a chain problem happens all the time.
Posted on Mar 15, 2009
What would cause the ridgid 10inch wet saw blade to not cut straight?
damaged teeth on one side not cutting evenly so the good teeth on the other side allows the blade to veer away from a straight cut
Have the blade resharpened
Feb 17, 2016 | Blade Saws
When sharpening the chain saw chain what is the filing angle?
same as the angle of the chain. It is recommended you use your round file that accommodates the size of the tooth of the chain. count the cuts or motions (each tooth should be filed the same amount) if you cut the first tooth three times cut the balance three times. keep the exact angle of the tooth and do not deviate or the chain will not cut as well. if you over file and change the angle for the chain you are filing you may need to have a professional fix it or buy a new chain. the flat file is simply a light stroke to remove misc fragments off the top of the tooth or give it a sharper edge after the round filing is complete. when using a round file it is easiest to purchase a small holder so each stroke is stable and straight. good luck.
Oct 25, 2014 | Worx Wg303 16" 3.5-hp 14.5-amp Electric...
Why is my poulanpro 20 cutting at angle, what is proper sharpening angle. thanx
The manual should give the proper sharpening angle--the main thing is to make sure that all teeth are sharpened to the same angle. If you remove the bar and chain, look at the outer edges of the chain groove around the whole bar--you may find that the bar metal has worn is such a way that the outer edges are flared out beyond the surface of the bar. This flare tends to grip the cut and cause it veer off to one side. The cure is to file down this flare at about 45 degrees so that nothing projects. Hope this helps!
Jan 07, 2011 | Poulan Pro Chain Saw 46cc 20"
When cutting vertically down a piece of wood the cut veers to the left all the time even when i try to steer it right
You may have a slightly bend in your bar. Take something straight like a line level and put it next to both sides of your bar and try to see if you see the bend. If the chain is still tracking ok than the bend may not be noticable by eye. A replacement bar can be purchased at Lowes Home Improvement Center for around $30. If replacing the bar does not solve your issue Lowes will allow you to return it within 90 days. I if replacing the bar does not solve the problem I would recommend taking it to a Husqvarna repair Center.
Oct 10, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Hi, my mcculloch chain saw is not cutting properly. it will only cut on a angle, not straight up and down. the saw needs to be turned15 degree's to the right so that it cuts. it's like this / not I. cant...
Use a file around the perimeter of the bar at about a 45° angle, both sides. Remove just enough metal to see where the file has been. I think you have a wire edge that is causing the bar to cut at an angle. Be careful it is sharp. If that is not it post back below. Good Luck. HTH
Lou
Feb 23, 2010 | McCulloch Garden
20" poulan chain saw cuts at angle
Hi
You must have hit a nail or stone with the one side of the chain. When the chain gets duller on one side than the other is what makes a saw cut at a angle. Get the chain sharpened and it should cut straight again.
Sam
Jan 08, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw cuts great at start, not so good about 1/2 way
All things are possible but it isn't likely the bar is bent. Are you getting fairly large chips or sawdust? Try raising the rear of the saw a little when she quits cutting. so you have a small contact area instead of a wide flat cut. Run a flat file at an angle along both edges of the bar to remove any wire edge. Let me know what you find you have piqued my curiosity. Lou
Oct 01, 2009 | Garden
Not cutting in straight line
Normally blade overheating. Improper blade or too few teeth for material, teeth not sharp and/or offset enough for proper width of cut. Teeth must cut wider than blade. Inexpensive blades tend to do this quickly. Other possibility: Bad bearing, check for play with saw unplugged. Blade should have little wobble. Other possibility: Saw body cracked/damaged(allowing shaft to skew) or very cheap saw unable to handle material
Sep 25, 2009 | Saws
I have a husqvarna 350 chainsaw, it wont cut straight throuh a log without cutting at an angle and getting jamed. what is the problem , any sharpening tips
THE ONLY THING THAT CAUSES A SAW TO CUT ON A CURVE IS THE CHAIN IS SHARPER ON ONE SIDE THEN THE OTHER AND IT PULLS THE SAW CHAIN TO ONE SIDE CAUSING THIS PROBLEM.
THERE IS NOTHING WRONG WITH THE SAW, IF YOU USE A FILE TRY A FILE GUIDE THEY WORK GREAT
Sep 17, 2009 | Husqvarna Garden
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
2,620 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
