Question about Garmin StreetPilot C330 GPS Receiver
Sending maps from PC
I have street pilot c330 mith 2GB Hard disc and I cannot send maps from pc with mapsource becase i get and error saying not enogh memory on the unit. anybody nows what can i do?
I assume the c330 is still working ok apart from this problem. do you mean hard disk or memory card ? either way you need to make sure that you have not duplicated your maps first of all you can also free up space by removing additional voices that you do not use also is it a 2 gb card?
Posted on Aug 27, 2007
SOURCE:
POS Garmin Streetpilot C330.... HELP REQUESTED!
I think this one is a return to seller or send to Garmin.
Jul 05, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot i3
after i send the map with mapsource from first minnutes is not seen the detailed maps what were transferred but after the receiver catch signal it apears my map detailed
i put gmasupp.unl file to garmin folder from microsd with key from keygen 1.5 i dont know if its necesary but its working with road 2008 romania @ europe nt v9
Mar 26, 2009 | Garmin nuvi 200W GPS Receiver
I TRIED TO UPDATE MY GARMIN 330 STREET WITH THE NEW DISK
TO GET 2009 MAP IS NOT EASY! Software update is, from the Garmin site you can update software easily BUT THE MAP... you must purchase for $69.99 OR if you're a technical person who knows the following instructions you can save some $$$
search torrent for
"CNNANT2009-1 MapID 396"
under torrent sites, you know what you're doing.
Use these instructions if you have downloaded it.
Download these first:
cgpsmapper.exe
gmaptool.exe
MapSetToolKit.exe
and MapSource where u can directly get from Garmin site
http://www8.garmin.com/support/download_details.jsp?id=209
Create these folders on the root drive: (I will choose one to make things easier, you can change)
C:/grmtmp
C:/grmtmp/extract
Connect your GPS to USB, and BACKUP then remove
X:/Garmin/gmapprom.img and gmapprom.sum (may be gmapsupp.[img+sum]) approx. 1GB
1) Copy gmapsupp.img from this torrent to C:/grmtmp;
2) Extract gmaptool.exe, cgpsmapper.exe and mapsettoolkit.exe to C:/grmtmp/extract
3) Open a command prompt, and navigate to the extract folder ("cd/grmtmp/extract")
4) Run "gmaptool -S ../gmapsupp.img" Note that is -(CAPITAL S), lower case s is for different option
5) The above will extract files, you will get some warnings about 10 degrees. Ignore them.
6) Run "cgpsmapper mapset00.mp"
7) Run "MapSetToolKit"
8) In MapSetToolKit, press "Install A Existing Mapset"
8a) TDB File: "mapset00.tdb
8b) Overview map: "mapset00.img"
8c) Registry name: "WhateverYouWant" (I did "Grm2009.1Update")
8d) Leave TYP files blank, and hit "Install"
9) Close MapSetToolKit and run MapSource
10) Ignore any requests to unlock map, not ready yet.
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Ender 396 for the FID/MapID, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Feb 23, 2009 | Garmin StreetPilot C330 GPS Receiver
Backup Streetpilot C330
HOW TO INSTALL CN NA 2009NT ON A STREETPILOT C330
The CN NA 2009 NT mapset is too large to be installed in the C330 without putting part of it onto an SD card. My recommendation is to use MapSource to build an image file containing the lower 49 states, PR & the USVI and upload it into the internal memory as a new 'gmapprom.img' file, and then build a new 'gmapsupp.img' file for an SD card containing Alaska & Canada.
Start the process by using MapSource to create a new 'gmapsupp.img' file, choosing the lower 49 states plus PR/USVI. Make sure that the total mapset size is no more than 975MB (930MiB) MAXIMUM. Anything that's very much larger will cause the installation to fail, due to insufficient internal memory. Note: Even though MapSource lists the mapset size in "MB", it actually measures it in "MiB". DO NOT EXCEED 930.0 MAPSET SIZE AS LISTED IN MAPSOURCE! (Can you get away with "just a little bit more"? Yes, you can, but why push it when you can simply put the rest on an SD card? Otherwise, you'll spend 40 minutes uploading it to your C330, only to have it fail at 99%. No fun... )
After selecting these maps tiles, choose 'Transfer > Send to Device...', but do NOT select your C330 as the destination for your new 'gmapsupp.img' file; instead, choose to send it to a blank 1GB (or larger) SD card plugged into one of your USB ports by way of an appropriate adapter (or to the 'C:\Garmin\' folder on your primary hard drive if you're running a specially-modified MapSource executable). MapSource will automatically create a 'Garmin' folder on your SD card and create your new 'gmapsupp.img' file within it.
Once you've successfully accomplished this task, copy the new 'gmapsupp.img' file to your hard drive's 'C:\Garmin\' folder (unless that's where you sent it in the first place, as noted above), then re-name it 'gmapprom.img'.
Next, repeat the process, selecting Alaska plus all Canadian provinces instead. Do NOT select any of the U.S. map tiles you selected the first time around. Capiche? This time, however, after creating the new 'gmapsupp.img' file on your SD card, do NOT copy it to your hard drive and do NOT re-name it. Just plug your SD card into your C330.
Finally, we're almost ready to upload the first file you created -- now called 'gmapprom.img' -- into your C330. First, we have to make sure you have a copy of Garmin's WebUpdater package installed. Open your 'C:\Garmin\' folder. Is there a 'WebUpdater' folder there? Yes? Great! Look inside and you should see a file named 'WebUpdater.exe'. If you've got it, you're almost there.
You don't have WebUpdater installed? Go get it and install it; it's a free download from Garmin. I'm using Windows XP; be sure to get the Windows version that's right for you. (To the best of my knowledge, this procedure does not work on a Mac. Sorry... ) http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Now that you've got it installed, do the following:
- Right-click on an unoccupied area of your Windows Desktop; when the menu pops up, choose 'New', then 'Text Document'.
- Double-click this document; this will open up a brand new blank document in NotePad (or whichever text editor you've chosen).
- Copy and paste the following line of text into it...
C:\Garmin\WebUpdater\WebUpdater.exe /upload_file rgn=49 path=C:\Garmin\gmapprom.img -autorun usb /i
- Select 'File > Save' then 'File > Exit'.
- Re-name the file to 'C330_Map_Update.BAT'
- With the C330 connected to the PC by USB (your drivers have already been installed previously, yes???), double-click on your new 'C330_Map_Update.BAT' file.
- Sit and watch as the WebUpdater application opens up a command-line window and copies your new 'gmapprom.img' mapset into your C330!
- It will take approximately 35-40 minutes if all goes well.
-Don't forget, you'll need to have previously entered your 25-character unlock code into MapSource. That unlock code must be specific to your C330; just because your Nuvi's unlock code allows you to create mapsets in MapSource doesn't mean that those mapsets will work in your C330!
Jan 15, 2009 | Garmin StreetPilot C330 GPS Receiver
Loading to usb data card programmer
you can not see the data card programmer as a drive in My computer , but you use Mapsource to send dat to your card
May 09, 2008 | Garmin StreetPilot C330 GPS Receiver
POIs for Street Pilot 2610
Sometimes going to Garmin's web site can help answer questions like this. Garmin has discontinued the StreetPilot 2610, which means it has not been produced for some time. This is from the manual of the 2610/2650:
CD-ROM:
Accepts downloadable map detail from
Garmin PC-based MapSource® City
Navigator™ DVD (included), which
provides street-level detail, addresses,
listings of nearest restaurants, hotels,
ATMs and more. Note: Requires
CompactFlash® card (128 MB CF card included)2
Feb 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Powers up but then stops with a message
Turn on the Garmin and look for the little wrench. Press the wrench and now find Map. Press Map and look for Mapinfo. Press Mapinfo and verify that there is a check mark next to the Mapsource Map.
If you press Mapinfo and there is nothing, then your Mapsource upgrade did not go through.
Jan 08, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Error message on screen (read message below)
Did you tried to update your Maps? There are two maps inside your Garmin. Basemap which covers all highways and major roads and mapsource source which cover regular streets. Try reloading mapsource maps.
From the "Where to" menu select the little wrench and then select map and then select Map info. What does it say for Map Info?
If the unit is still under warranty, call Garmin and get a RMA. Return the unit to Garmin.
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
Map problem
There are two type of maps in the unit. There is the basemap which shows the states and major highway and roads and then there is the actual Mapsource maps which shows the streets. If you go to Mapinfo and it doesn't show anything, then Mapsource maps are missing.
With the 2610 you can use a card reader for the Compact Flash Memory card to load the maps. This is much faster since the card reader is USB 2.0 while the Garmin USB is 1.1 Under device look for the drive letter which correspond to the Campact Flash card.
Oct 15, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
82 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
