Question about LG WM-2277HW Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
THIS HAPPENED ONCE BEFORE, SHORTLY AFTER THE WASH CYCLE STARTS IT STOPS AND THE LE ERROR MESSAGE APPEARS.
BEFORE I CLEANED OUT THE BOTTOME FILTERS AND IT STARTED WORKING AGAIN WITH NO PROBLEMS FOR ABOUT A YEAR NOW. THE WASHER WAS 2 YEARS OLD IN NOVEMBER08
  • Haxwell May 01, 2009
    My washer stopped in the wash cycle with an LE message. I started it again, and it failed. Started again, and it failed. All with an LE message.
  • 66 Answers
Error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Posted on Jan 15, 2009
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
Washer stops cycleing
First are you sure the error code is 'LE' and not 'tE' which looks very similar. The LE is usually the motor position sensor. Common on older washers. Easy fix. Under $20 part. The tE error is usually the thermistor. Inexpensive part about $6, but can be more complicated to get to. Ad a comment to your question and my answer with error code and I'll reply with more info if needed.
Jun 24, 2017 | LG WT4870CW 4.5 Cu. Ft. Top Load White...
I have a DE code on my LG Wm1832cw front load washer. This happened last weekend, and we found that the small drain hose in the front was clogged so we got the clog out and the washer has worked great all...
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service manual
May 27, 2011 | LG WM-2277HW Front Load Washer
My LG WM1832CW is blinking LE on the readout. what's wrong?
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Jul 30, 2010 | LG WM-1832C Front Load Washer
LG washing machine problem.
LE is a locked motor error
make sure that all your connections are secured
Dec 29, 2008 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
LG WM1832CW
hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Oct 16, 2008 | LG WM-2277HW Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
OE message on our LG WM1832CW washer
I just was searching for the same exact error on my LG WM1832CW washer. From reading the other posts on different manufacturers I realized this was a pump clog issue for mine too. There is a small door near the bottom of the front of the washer and if you open that there is a filter basket. Once you start turning it and break the seal, the water will come out quickly, have 2 flat large tupperwares so you can catch the water. Once you clean out that filter it's good to go. A 5 minute job.
Jan 21, 2008 | LG WM0642H Front Load
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,075 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
