Question about Star Micronics TSP600 Thermal Printer
Blinking red error button
Cannot print receipts for customers. Light is blinking red
    Problem Solver:
  • 9 Answers
Blinking light can be caused by a multitude of problems, but in most cases it is caused by the little white switch that you see when you open the printer lid to install paper. Has to be replaced by a printer technician who can get the part from star micronics. Another cause is bad cutter or paper out switch located under lid at the back of printer in which the paper pushes the switch into the side of the printer. None of these problems can be solved by an end user.
Posted on Feb 23, 2009
I have a ml-2165w laser black printer, when try to print it tells me me disconnect and press on button, the light turns green then blicks then turns red. What do I do>
Dear
There may be some error related to fuser or LSU.
Pl. down load samsung easy printer manager from samsung site or it can found on the disk provided.
run it it show the error detail.
Thanks
Oct 06, 2014 | Samsung ml-2165w - laser printer -...
I have a casio pcr-t500. Is it possible to print 2 receipts for a transaction?
I service many computerized cash registers, though none of my customers have Casios. Everything else Casio makes is great though, so I have no doubt this is a great machine.
Here's a PDF of the manual for your specific unit and a possible solution that works for me across many different platforms and brands:
http://www.casio4business.com/sa/products/downloads/manuals/PCRT500_INC-e.pdf
On page 18 of this manual, there is a list of all the main buttons. Every machine I've seen has had button like number 2 on that page (to print a final receipt). What all of the employees of my customers do to print out two or more receipts is just hit this button again after it prints out the first one and that works like a charm. I hope it'll work for you.
I also saw many cool options you could set so that it would print out different kinds of receipts, such as sale reports with specific information on them. It might be worth looking into as there may be another way that works even better for you.
I wish you the best of luck! :)
Mar 06, 2014 | Computers & Internet
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My tsp600 receipt printer will not print and the error light is on.
Dear Oasis Pools,
Please advise if the error light is flashing or solid. Also, perform a self test by turning the printer OFF, hold the feed button down, then turn the printer ON at the same time. A self test should print out. Did this print?
Regards,
Star Customer Support
For further assistance, please contact our Support Team at 800-782-7636 Option 2 for Tech Support or support@starmicronics.com
Feb 13, 2011 | Star Micronics TSP600 Thermal Printer
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Canon Selphy CP510 Thermal Photo Printer
Green and red light on doesn't print
Maintenance request error is not cleared until the waste ink pad is replaced with a new one, and the waste ink counter in EEPROM is reset by the service operation.
"try in this procedure
1. hold and press ink and roll button then press power on.
2. Red Led 10 times blinking
3. release roll button.
4. press ink button until all light blink at a time
Dec 31, 2009 | Epson Stylus Photo 1290 InkJet Printer
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Both red lights on my printer are blinking
Blinking wit general error message : head carriage error. It cause by head cannot move to parking position or chip at ink tank not good connected. Try to use another chip. Just turn off printer for a moment for clearing epprom.
Nov 09, 2008 | Epson Stylus C83 InkJet Printer
Star Micronics TSP600 Thermal Printer Logo
3,483 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
ray gallant
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
