Question about Epson Stylus Color 1160 InkJet Printer
All lights are flashing on my epson 1160, I had just replaced the black ink and have had this problem since. anyone know what to do?
The SECOND solution posted by SLICK54 worked for me (after a few tries). I was about to give in, when it just happened. THE MACHINE RESPONDED.
Follow the procedures as HE states.
Best of luck.
Grovense
Posted on Apr 06, 2009
All light flashing on epson stylus sx105
Epson Stylus Printers all lights flashing 1160 760 860 etc ..
just found this for you not saying it will work for your printer but give it a try.
Nov 22, 2016 | Epson Office Equipment & Supplies
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
I used a substitute black ink cartridge and now the red light is flashing and the monitor message is that parts inside require maintenance or replacement. I need to know how to take out this non-epson...
if you light is flashing alternatively, this mean the waste ink counter need to be reset and the waste ink pad need to be replaced.
you will need to download the resetter the link below..
http://inkjetprinterhelp.us/epsonSSC.html
May 28, 2010 | Epson Stylus 680 InkJet Color Printer
All lights are flashing and we cannot reset, have you any suggestions
I had a smilar problem on a HP Printer, not sure what printer your's is but you can give this a quick try, Turn the printer off, then turn it back on again while pressing both the ink and paper buttons at the same time. As soon as the paper light flashes let go of both buttons, then quickly press and hold down the ink button for 10 seconds. Hope it helps, if not could you let me know the make of your printer and I'll ask a few of my fellow Cleaners ;)
Good Luck
Garycleaner
May 04, 2010 | Epson Stylus Color 1160 InkJet Printer
Flashing ink cartridge lights, soild paper light
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 31, 2008 | Epson Stylus Color 1160 InkJet Printer
MY EPSON STYLUS PHOTO R200 HAS THE RED A GREEN LIGHT FLASHING
WWW.EPSON.COM/SUPPORT AND DOWNLOADS, WHEN YOU FLIP OPEN THE COVER SEE IF THE UNDERSIDE HAS A INSTRUCTION APPLET ON CLEANING AND REPLACING INK CARTRIDGES, THOSE LIGHTS MEAN 2- THINGS RED-LIGHT, INK IS TOO LOW,NEEDS REPLACEMENT, RED WITH GREEN AFTER REPLACEMENT CLEAN HEADS, I HAVE SAME PRINTER , NOTHING MAJOR, USER GUIDE IS ON SITE ALSO IN PDF, FORMAT.... JON T
Dec 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Printing partial color no black
Did you remove the plastic protector on the ink cartridge before you installed it?
Nov 06, 2008 | Epson Stylus Color 1160 InkJet Printer
Epson 1160
before it went to flashing all lights, was there anything that was either done to the unit cleaning, ink install ect.
also I would run through all the cleaning procedures of the unit as well click the below link
http://files.support.epson.com/htmldocs/sc1160/sc1160u1/INDEX.HTM
and then goto the Maintenance section of the manual.
was there any grinding noises and other sounds on the last printing?
Oct 13, 2008 | Epson Stylus Color 1160 InkJet Printer
Hello Stompson,
You can go here and download this utility. It will allow you to select your printer model so you can reset the maintenace request.
If in the event this does not work try this 2nd procedure, it normally works with the older Epson models and may work for your model too.
1. turn off the machine for at least 5 minutes and disconnect the interface cable to the computer
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
Aug 18, 2008 | Epson Stylus Color 1160 InkJet Printer
Epson Stylus Color 1160 InkJet Printer Logo
407 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
