Question about HP LaserJet M5035 MFP Printer
I need a free HP M5035 Service Manual
I had a bad sticker jam and removed a cover inside the paper exit assembly and now I need a service manual to help me put it back on. Any sites you know of with a free manual?
You can try this site i exchanged a manual to get the M5035 SM free http://www.free-service-manuals.com/Detailed/74071.html
Posted on May 16, 2009
  • 3 Answers
Hi any HP Manual FREE from this site.
http://www.printersupplies.com/manuals.html
Posted on Jan 06, 2013
I bought one.
Posted on Jan 16, 2009
Paper is jam under the roll
You have to disassemble the printer to effectively remove an 1100 jam...
The covers have to be removed and the fusing assembly needs to be partially disassembled.
You probably need a service manual... This printer is not simple to take apart.
It is probably cheaper to get another one on Ebay.
Nov 02, 2010 | HP LaserJet 1100 Printer
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
C4180 paper jam problem
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Apr 26, 2009 | Office Equipment & Supplies
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Fuser Assembly damaged by user trying to remove paper jam.
This is one of those that is not quite so easy. I have uploaded the service manual for you. You may download it here.
Thanks and please take a moment to rate this solution as fixya as I have taken the time to upload the manual for you. Good luck!
Feb 14, 2009 | HP LaserJet P2015dn Printer
How do you fix a paper jam?
Feb 14, 2009 | HP Photosmart C7280 Laser Printer
Paper jam message but no paper is jammed. how do i fix it (hp officejet 55210 all-in-one)
Jan 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to clear paper jam
Jan 04, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Printer had paper jam
Dec 06, 2008 | HP Deskjet 6940 InkJet Printer
Paper jammed in area 5. Removed #6 and started to pull paper out, but it tore and will not release the remaining part.
Nov 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP LaserJet M5035 MFP Printer Logo
3,802 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
