Siemens WFXD8400UC Front Load Washer
Problem for Siemens WFXD8400UC Front Load Washer
REALLY NOISY
By mandy662 on Jan 15, 2009
Hi, I have had my Hotpoint WT741 for two years and just lately it seems to be really noisy - in fact it sounds like an aircraft landing in the kitchen! It really is deafening. I don't remember it being that noisy when i first bought it? Can you help please.
Same Problem
Apr 27, 2009
-   The suspension struts are worn out have a look at espares about £20.00 each i replace both of them
steve -   Guest
Best Solution
posted on May 04, 2009
Very Helpful)
mjbryan81
Rank: Apprentice
Rating: 100%, 2 votes
posted by mikey b from st Helen's. after experiencing a similar fault on my wt741.i set about determined to find the cause of the noise.On spin,particularly fast spin the washing machine was making a horrendous vibrating banging noise.i eventually traced the fault to the lower concrete weight which simply needed tightening. which is held on with 4 10mm bolts.the weight can be easily accessed by turning the washer on its side.support the outer drum with a small block of wood against casing before lying on its side. you will need a 10mm spanner to get on bolts.hope this was helpful !
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jan 15, 2009
Somewhat Helpful)
duby1990
Rank: Guru
Rating: 87%, 226 votes
YOur bearings in the back of the tub have worn out! This is caused by using powder soap. This is a very common problem and is around 400 bucks to fix.
Was this helpful?
Yes
No
Popular Solutions for Siemens WFXD8400UC Front Load
Questions and Unsolved Problems for Siemens WFXD8400UC Front Load
Do you recommend Siemens WFXD8400UC Front Load Washer?
Answer
Answer
My drum wont spin...it goes through the entire wash cycle but when it comes to spin - drum will not... (More)
Answer
My machine isn't spinning once cloths are wet
Answer
Not draining the water , not finising the spinning cycle
Answer
The door seal is leaking. maybe a zipper or similar got stuck and made a small mesh in the grey... (More)
Answer
how do i undo the child lock on the siemens extraklasse 753
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Siemens WFXD8400UC Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
