Question about Kenmore 54501 Dehumidifier
Autoshutoff does not work
Hi,l I have no manual for this dehumidifier and last night it overflowed. Is there anything I have to do to make sure the auto shut off switch is working? Thanks
  • 105 Answers
The only thing you can do is make sure the pail is properly seated. Manually activate the switch to make sure it is working.
Posted on Jul 17, 2007
SOURCE:
How do you hook up a drain hose to a Fedders dehumidifier?
Personally I would contact fedders and ask them ( their experts) that is
Oct 14, 2015 | Fedders Dehumidifiers
Tip
How to repair or fix a Dehumidifier when it leaks or overflows
Nine times out of ten, a problem with a dehumidifier can be traced to electrical parts-not to the compressor. If the problem is being caused by the compressor and the unit is out of warranty (most have a 1-year limited warranty), strongly consider replacing the unit rather than trying to have the compressor repaired. If you're thinking about having the unit repaired, be sure to ask for an estimate.
Unless it is designed to drain automatically, a dehumidifier should be emptied fairly often during hot and muggy or damp weather- sometimes as often as once a day. In humid, damp climates, a dehumidifier's reservoir can pull as much as 50 pints of water from the air a day. Failure to keep the reservoir clean and dry will just contribute to the problems you're trying to solve. If you're in the market for a new dehumidifier, consider its reservoir capacity: Larger capacity reservoirs work more efficiently and have to be emptied less often.
Many dehumidifiers have a float switch that prevents the unit from spilling over with the water that has been drawn out of the air. Sometimes this switch goes bad and must be replaced. If your dehumidifier is overflowing, you can test the overflow prevention switch with a volt-ohm meter.
1) Unplug the dehumidifier and remove the switch.
2) Disconnect the leads and clip the leads to the terminals on the switch.
3) Check the pan or reservoir and empty it if necessary, or make sure the drain isn't clogged.
4) Straighten any kinks or bends in the unit's hose.
5) Set a volt-ohm meter to the RX1 scale (or to K-ω or ω resistance on a digital meter) and depress the bar or trip lever on the switch. If the meter's needle shows no continuity as the switch is clicked back and forth, the switch is probably faulty and will need replacement.
on Sep 15, 2010 | Dehumidifiers
The bucket fills up but we have to put a towel down because it leaks all over the floor. What could be wrong ?
Good Afternoon Friend,
I understand that the bucket fills with water and overflows on your Frigidaire dehumidifier, model# FAD704DUD. Please make sure your dehumidifier is installed on a level that will support it with a full bucket of water. If the dehumidifier is moving when it fills with water then this could possibly be the cause of the bucket overflowing. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FAD704DUD 70 Pint Dehumidifier
DANBY DDR7009 REE dehumidifier "Auto" shut off Malfunction
See previous answer. If new, contact supplier to replace float switch. Are you sure it's not just a fan staying on with the tank out?
May 15, 2012 | Danby Dehumidifiers
The dehumidifier stopped collecting water. It was working great, then just stopped collecting water one night.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 17, 2011 | Bionaire Dehumidifiers
Hi, Kenmore Dehumidifier 4254501. Brand new last
Now that you've had a chance to vent your frustration, Mike. Did you check the outlet the unit is plugged into, to make sure that it's working? Amazingly enough, I answer questions like yours all the time. And, you know what? 80% of the time, the problem is with the outlet. It's either the circuit breaker was tripped or the interior of the receptacle was damaged. And that's not counting a loose wire connection on the receptacle. So, either test the receptacle or plug the unit into another one, that's on a different circuit.
If by chance you have to replace any parts, your Kenmore Dehumidifier was manufactured for Sears, by Whirlpool. So, parts are interchangeable. And, as my son says, "If all else fails, read the Owner's Manual.
Jun 09, 2011 | Kenmore 54501 Dehumidifier
If my dehumidifier seems to be working fine( fan comes on and all buttons work) and its not picking up water anymore could there be some other reason that its not filling up? We did also fix a few leeks in...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Aug 23, 2010 | Frigidaire FDL50R1 Dehumidifier
Very little water collection after running all day an night
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 23, 2010 | Maytag M7DH65B2A Dehumidifier
Will not run after a few seconds
sounds like a main pc board and or capacitor problem
Sep 17, 2007 | Kenmore 54351 Dehumidifier
Haier HDN655E Dead
There is an internal fuse. Take off the outer plastic casing. The fuse is on the bottom of the board on the upper right of the unit. It's a 12 amp fuse. I had the same problem and found the fuse blown.
Aug 10, 2007 | Haier HDN655E Dehumidifier
Kenmore 54501 Dehumidifier Logo
130 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Marvin
Marvin
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
