Windows XP stopped recongizing eGo external Hard Drive I just installed a new iomega eGo 1 TB desktop Hard Drive yesterday, got the bugs worked out and my Dell w Windows Xp seemed to recognize it, Today, I started the computer and it won't recognize the external hard drive except to say there is a failed device in the usb port. How do I get it to recognize the desktop hard drive?
  • jyllianm May 05, 2009
    eGo Iomega external hard drive just stopped working. MY XP system sees it initially and tries to 'autoplay" it and then it hangs. Nothing comes up.
    Files are visible but not accessible on Linux.
  • 298 Answers
2 things... the USB port is bad, or the USB cable is too long and the HDD isn't getting a good signal.
1. Try another port and see if that works
2. Nip over to WalMart, Circuit City, Micro Center, PC World or Best Buy and get a shorter, Thicker USB cable of the same type - a cable which can provide the signal strength your ext HDD requires.
Also a possibility... The HDD may be 'lost' as Win cannot accept one of that size or the label/signature fell off and it is an orphan. It MUST have a driveletter, and it MUST have a special WIN signature byte on the HDD for it to work.
Bootup as normal, let everything get quiet, then plug in the ext HDD
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass icon and wait. This forces your OS to 'Look' for any new devices.
When it finishes looking, look again under My Computer to see if your new HDD is now there. It will have to be formatted and have a driveletter for this part to work. Jump down to Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-) If it is not, use a shorter, thicker (more wires) USB cable and try again.
Windows doesn't like Any HDD without win signatures on them - aka:'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it, then Rt click it and give it a Diskletter.
Posted on Jan 16, 2009
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
My hard drive simply stopped working yesterday. I took it to Best Buy, Geek Squad says it is not the cord but where the cord goes in as no "power" is getting to the drive when plugged into my laptop - they...
That sounds like what they would try to do, things that could be wrong is the converter board might have fried, if that is what it is then it can be easily opened up and plugged in to test it. If that is the problem then all the data should be recoverable.
Sep 18, 2013 | Iomega eGo BlackBelt Portable Mac Edition...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
Win 98 Drivers for Iomega Prestige 1 Tb external drive
Windows 98 does not have an USB driver, You may get one from the Iomega WEB site for this external hard drive.
Feb 05, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
My Iomega external ego hard drive(360GigaBytes)will cause my H.P. Pavilion with windows 7 to randomly restart while transferring data.
I had a similar 'rebooting' issue with my WD external drive caused by a faulty USB interface on my Desktop: if you have an external USB hub, try running your drive via the plug-in USB Hub to shield your external drive from your desktop inbuilt USB electronics..
Dec 25, 2009 | Iomega 360 GB USB 2.0 Desktop Hard Drive
My external hard drive does not work on windows xp
You might need to initalize it in XP and then assign a drive letter.
Aug 29, 2009 | Iomega 250GB Ego HD USB 2.0/FW Red 250 GB...
Computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Jul 24, 2009 | Computers & Internet
check for updated drivers
or unistall previous driver & install updated one
May 18, 2008 | Iomega Portable USB 2.0 & FireWire 400...
Computers & Internet Logo
376 people viewed this question
David Payne
David Payne
