Question about Symphonic ST419E TV
Tv remote dosn"t work
Hi last mouth my uncle pastaway and he gave me a 27 inch symphonic standed tv.I brought it home and hook it up and it worked finei but batties in the remote and it work then i set the sleep timer and when i woke up the next morning the remote did not work please help
  • 45 Answers
Check with new battries, and if you have a camera phone you could see the front IR bulb lighting up when seen through the phone display. Patrick
Posted on Aug 27, 2007
I have a symphonic 27 inch tv and need the code
Google the model number of remote and the set for "manual" which should have possible codes.
With the manual for the remote look to see if it has a search mode which will allow you to try every possible code one at a time to find one that works.
Universals even if programmed will be missing key features the original remote had.
Apr 23, 2012 | Symphonic wf27f4 27 inch Flat panel TV
I have a 27 inch symphonic crt tv. i have a bell satellite reciever hooked up to it with the renote programmed for the tv. i accidentally hit the mute button and now there is a 2 on each corner of the tv...
hi there, plugging and unplugging won't work that way. Pls try This:
1. look for the Program menu of your bell satellite unit
2. under menu you will see the settings there and try to reconfigure it or reset the current program.
3. scan for available channels and save it. i hope this will help you a little. Thank You.
Feb 07, 2011 | Televison & Video
27'' symphonic TV. Sony remote wont work since switched 2 digital
Use the channel buttons on the unit to go down past channel 2, usually you can get to the inputs this way.
Aug 09, 2009 | Sony Televison & Video
OLD REMOTE NEEDS PROGRAMING
Each Remote is Different... it will only work if the IR Codes Match your TV.. if they dont then you have no hope of getting it 2 work.. most likly just through it out... coz its prob just cheeper to buy a universal one from your local supermarket
Jun 08, 2009 | Proton MM2701VT 27" TV
Tv won't recognize remote codes
If the manufacturer of the universal remote cannot give you codes for the Symphonic you are out of luck. U will either have to get an original replacement or get a Harmony universal remote.
Jun 25, 2017 | Universal Remote Control Remote Control
Game mode issue, remote needed!!!!
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote.What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Apr 26, 2008 | Symphonic ST419E TV
Remotes quit working
Take your Tv to the Technician to check for you if the sensor is working properly.
Mar 24, 2008 | Symphonic ST419E TV
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Mar 04, 2008 | Symphonic ST419E TV
Remote randomly works. 27" Symphonic TV... but remote works on other Symphonics in the house
I would get a new remote control first. Just because it is the same brand doesn't mean the same reote codes are used.
Apr 05, 2007 | Symphonic ST419E TV
Symphonic ST419E TV Logo
113 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
