Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
No heat from phillips whirlpool diswasher
Question posted yesterday. No solution received as yet.
  • ivorbrown Feb 12, 2009
    There seems no spare parts for the Phillips dishwasher ADG600 e.g heating element,temperature stat,etc. Are there any suppliers?
  • 32 Answers
Hi, if a dishwasher is not heating up, it can be 3 different things. The most common (on Whirlpool) is the temperature stat, located underneath the machine (small cylinder fitted on the housing), the 2nd will be the element and 3rd will be the PCB.
Posted on Feb 12, 2009
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 14, 2011 | Dishwashers
The dipnser door won't open, so the tablet isn't released into the washer during the wash cycle?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Mar 22, 2011 | Dishwashers
The soap does't disolve just lies in the bottom of the diswasher, I've just used the diswasher about 10 times, brand new
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 18, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Sep 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How to protect my dishwasher in a non heated cabin in freezing t
hi there.......best to remove it from its position at the end of your summer vacation....drain it completley..of all water.....pack it into a container (large cardboard box etc) lined with polysterene etc....
regards Sir Galahad
Sep 03, 2009 | Dishwashers
Whirlpool dishwasher stopped working.
the t-stat under the diswasher is defect or the thermal fuse is defect its located on the main control. remove the inner door panel to get to it, check for contenuity for both items.
nbcrca:)
Apr 11, 2009 | Whirlpool 24 in. DU915QW Built-in...
Washer is off balance. Need to get to levelers.
I had the same problem...thanks for posting a solution. I agree with the solution posted above, but on my unit they are 1/4" HEX head screws, not phillips. Look at the illustration on page 4 here for help:
http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/XHP1550VB_Installation%20Instruction.pdf
I hope that helps.....
Dec 30, 2008 | Whirlpool LAB2700ML Pedestal Drawer for...
Diswasher detergent door
lizzie1 First thing check if the lower dish rack is in right position. If it is in wrong position it is not enough room for the lid to pop up open. Try to turn the dish rack around and see if it works. If not, then I'll need the full model number for your dish easher. Gendos...post back
Jan 28, 2007 | Whirlpool 24 in. DU850DWG Built-in...
Dishwasher will turn off
Mami, first see if you can put it through a test cycle by pressing the heated dry button six times and then press start. 88 will display. This will test all the funtions of the dishwasher. Let it do it's thing for approx. 20 minutes. Wash motor should run. If it doesn't call for warranty service so you don't void it. It's possible something got messed up during installation. Catriver..post back.
Jan 04, 2007 | Maytag 24 in. MDB8751AWS Stainless Steel...
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
104 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
