Monitor shutdown My computer intermittently shuts the monitor down after it has been running and has set idle for an hour or two. The only way I can get it back on is to reboot the computer. I have a PM800-M2 (1) motherboard with a Pentium 4 3.2Ghz processor. My monitor is an Envision 17'' CRT. The green light on the monitor turns to amber when it looses its signal. My experience tells me it could be the onboard video and if it is would adding an AGP video card possibly resolve this problem?
  • leehart_2000 Jan 18, 2009
    I have not had a chance to try to fix the problem yet as I am waiting for an AGP card to replace the onboard video. In Power Options I have hybernate selected because I am using an APC UPS. This may have something to do with the monitor shutting down also. Will report back as soon as I know more. Thanks for the help.
  • 114 Answers
Yes adding an AGP video card will likely fix it. Although you try not turning off the hard drive(s) and if that doesn't help, not turning off the System Standby in Power Options.
Another thing to try is open MSCONFIG and stop all start up Items under Selective Startup. If it goes away you need to find out which program is causing the problem.
Posted on Jan 15, 2009
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Computer idles high then shuts down
When you say "idles high" do you mean you hear fans spinning faster or louder? If so, a fan spinning at higher than normal speeds is indicative of components/chips being run aggressively causing them to run at much higher temperatures. You may want to look into getting temperature monitoring software like CPU-Z to monitor the temperatures of your CPU and GPU. These components are the most common ones to be running at high temperatures. If any fan has failed on them the secondary fans (if there is one) will run at much higher speeds to compensate. Your PC may have a safety precaution to automatically shut down if certain temperatures are reached to prevent permanent damage to the components. Are you getting any blue screens before it shuts down?
Oct 16, 2013 | E-Machines eMachines Desktop PC
Monitor goes on and off........seemed to come on for the xp boot, but then disappears or is intermittant when the xp login page appears. Only fix sometimes is to reboot the computer. Very strange. Only...
In your Windows XP
  1. Go to Start and click
  2. The Start menu will open
  3. In the start menu click settings
  4. In the settings select "Control Panel"
  5. The Window of control Panel click "Power Options"
  6. In the Power options you will find Display time settings. These are the time settings that determine the time like if your computer stay idle for 5 min, the display will shut down.
  7. I suspect that this time is set to be very low like if there is no activity on the computer such as key punching, typically happens when you are reading an e-book Windows will automatically shut down the display. So you can increase the idle time to say 7-10 minutes and/or a similar setting is "Put the computer to sleep". Try to carefully alter the time values and you will find a good settings that work for you.
If the above tip does not work then there is definitely something wrong with your monitor's hardware most probably the power supply. You need to check it with a repair shop.
Good Luck!
Dec 09, 2010 | Xerox XG-71D 17" Flat Panel LCD Monitor
Moniter shuts down while playing wow while not in windows mode
Go to your computer's Control Panel, Power properties, and change the power scheme to Always On, where hard disk shutdown, monitor turn off and system suspend are all set to "never". This should help.
Dec 26, 2009 | Xerox XA7-17i 17" LCD Monitor
Every time I shut down my monitor stays on. How do i get it to shut off. It says monitor locked off . I always shut my computer off when I am done
Right-click on Desktop, go to "Properties."
From there you want to go to your power (or energy) settings. Here you should notice some settngs on your monitor and when it should sleep/shutdown.
Hope this helps!
Nov 10, 2009 | HP Computers & Internet
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Computer sleeps but doesn't come back on
With the amount of knowledge that you've given me, I would recommend going to your power setting in control panel and disabling the hard disk shutdown in the power settings. This will only turn off the monitor not the disk. If this gives you the same results, then your monitor is at fault.
Apr 09, 2009 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Acer Model AL1916W A reads no signal after being on for 1 hr
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
Fujitsu-Siemens Monitor problem
usually shut down when idle(idle means no key or mouse activity).........left click mouse in any space on desktop,select properties,in properties window select screensaver and lower in the screen youll see power power schemes change time best suited or select never.
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
481 people viewed this question
David Payne
David Payne
