Question about Central Dual Temperature Heat Gun Kit 3h201k
Gas furnace wont stay lit
Concord 80plus gas furnace(rcg8oa100o20-1a)
Lights three times then shuts down, has heavy clicking sound during and after lighting, runs for maybe 10 seconds each time
  • jeremy_prime Jan 16, 2009
    Is there any other circustances that may cause this same effect, I took part off and cleaned with no luck before I change out part can I test with lighter, could it be the bourd or the therastet itself
  • Anonymous Mar 12, 2014
    Flipping the switches on and off several times bring in back on
  • 80 Answers
Sounds like the thermocouple that senses when the burner ignites is faulty. when the burner is first lit it looks for a signal from the thermocouple telling it that it has ignition. i have had some luck removing the part (furnace off) and sanding it clean. this is located in front of one of the burners..Good luck
Posted on Jan 15, 2009
  • Bill Allen Jan 19, 2009
    iT COULD BE THAT THE THERMOCOUPLE IS BAD AND NEEDS REPLACEMENT. iF YOU HAVE ANY INDICATOR LIGHTS ON THE BOARD THEY MAY TELL YOU WHAT IS WRONG AS WELL. iT REALLY SOUNDS LIKE A THERMOCOUPLE PROBLEM TO ME BECAUSE IF IT DOESN'T SEND A SIGNAL THAT IT HAS FLAME THEN THE UNIT WILL SHUT DOWN THE FLAME. i WUOLD TRY TO REPLACE THE THERMOCOUPLE IF I DIDN'T WANT TO HAVE SOMEONE SERVICE IT. GOOD LUCK...
If I shut off the blower on my gas furnace do I have to shut down the whole furnace
Turn of the system at the thermostat. If you turn off the blower, assuming you mean at the tstat, there's no need to turn off the pilot. If blower is running and won't stop, even if turned off at tstat, turn off power by any means necessary, and pilot does not need to be turned off. A "standing pilot" is made to stay lit at all times, running or not.
Mar 07, 2017 | Heating & Cooling
Pilot on furnace wont stay lit
Sounds like the thermocouple is shot
Nov 09, 2014 | Dayton Gas Furnace Heater
Rudd furnace pilot wont stay
You have one of three things here
1. Dirty pilot, needs to be cleaned.
2. Bad thermocouple needs to be changed and pilot assembly cleaned.
3. Bad gas valve pilot solenoid call a repairman
Nov 09, 2014 | Heating & Cooling
Pilot on my gas furnace won't stay lit
Try cleaning the thermocouple tip if you can see ashes or any buildup on it. If you know the wind isn't blowing it out (had mine blow out from high winds before) then I would change the thermocouple before anything else.
Dec 09, 2013 | Heating & Cooling
Atwood motorhome furnace won't stay lit
I would say this is your electronic ignition system but it sounds like it is not getting gas. This is why they do a 3 time try and shut off. Check you supply line right down to the regulator. Hose could have got partially kinked along the line as well.
Jan 31, 2013 | Heating & Cooling
Goodman furnace gmh95090cxac wont stay lit keeps clicking will lite then clicks back off what would be the problem
Hello, if the burners light but do not stay on for more than 10 seconds, I would clean the flame sensor. The flame sensor is a metal rod that is on the opposite side of the Igniter, sometimes it gets coated by oxidation and does not sense the burner flame and shuts the Furnace down. To clean to kill power to tje furnace, remove flame sensor and clean with a steel wool, then reinstall and start Furnce back up. If this does not work then most likely the Igniter is too weak to ignite the gas and will have ro be replaced.
Oct 29, 2012 | Heating & Cooling
Rheem furnace problem wont stay lit
You need to see what it does. Does it light at all? will the pilot stay on? If lights but wont let you release the knob then thermocouple is bad. I
If it is electric start then watch the series of events. enducer fan motor starts, element heats up, gas lights but shuts off after 1 second. 5 seconds 1 minute and so on. Also your computer board on the furnace will flash a code indicating a problem. count the flashes and read the panel on the furnace for help it should give a description of the the errors.
all depends on the age and type of unit. respond if you have more questions .
Feb 15, 2011 | Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Pilot light wont stay lit.want to clean the orifice
You shut off the gas.
Shut off the power.
Remove the gas valve and burner assembly.
After cleaning and reassembly you must purge the system and use a gas leak detecting soap to verify no leaks before turning on the power.
Apr 15, 2009 | Heating & Cooling
Heater will fire but wont stay lit.
I assume that you are referring to a natural gas forced air furnace. If so you just described the symptoms of a dirty flame sensor. Remove the sensor with a 1/4" nutdriver. clean the flame sensor with a small piece of fine grit sandpaper or emery cloth. replace the sensor and turn the furnace back on.
Good luck.....
Apr 11, 2009 | Heating & Cooling
Central Dual Temperature Heat Gun Kit 3h201k Logo
2,219 people viewed this question
Top Central Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Central Tool and Hardware - Other Expert? Answer questions, earn points and help others
