Question about Brother PT-1000 Thermal Label Printer
Have Downloaded "instructions" for PT-1280.................
I don't use the label maker very much as I prefer to do mine through the printer - but others in the office like the label maker - but we have never had a set of instructions. I have downloaded them thinking that the instructions could be kept with the label maker. The print is so tiny it is very hard to read even with a magnifier. Enlarging them is just causing bluring. Anyone know where I can get page or even 1/2 page size readable instructions. I have tried the Brother web page and that was where the download was from. Thanks!
1. Your site and the search engine I used state "free" help - no plan or package mentioned.
2. My question was in regard to a PT-1280.
3. I simply asked if anyone knew how I could get the instructions for this label maker larger as the download has every thing squeezed on 2 pages with the type so small it can't even be read correctly without straining with a magnifier. It comes as a PDF file and cannot be cut - stretched or enhanced anyway that I know to do.
Thank you for your email asking if I would like find out about your plans. The questions I have would be related to my equipment I use at work and I am not even going to consider digging in my pocket for anything. The equipment I use at home is wireless and works excellently and as I stated originally I do everything - including labels and programming from my personal computer.
Posted on Jan 16, 2009
My Brother PT65 label maker powers up and when I push print...the rollers turn but the label does not print or come out.
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
May 20, 2015 | Brother BRTPT65 PT-65 Label Maker Printer
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
I would like owner's manual for the brother model #PT-1280,printer
You can go to brother-usa.com and click on the "support" tab, then scroll down a little and you will see "manuals". Click on that and enter the model # and you should be able to download the manual.
Jun 09, 2011 | Brother P-touch PT-1280 Thermal Label...
Brother PT1280 P-touch Machine User's Manual Download
You can download and print the instruction manual in PDF format from Brother PT-1280 support website by clicking this link
On the page which opens, click on the 'Download' button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader. Thanks for using FixYa
A 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Brother P-touch PT-1280 Thermal Label...
Brother HL 1280
is the actual model is Brother PT 1280 .. it';s a labeling p-touch..if yes..then you can download the user manual here...
http://www.brother.com.my/my/productDetail.asp?model=PT-1280&Rnum=241294
May 24, 2010 | Brother HL 1260e Laser Printer
How do I open the back of the label maker to refill it??
Here's a link to the manual from Brother (it will open a PDF file):
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_1280_1280SP_1280VP_EN_254.PDF
Oct 24, 2009 | Brother P-touch PT-1280 Thermal Label...
My PT 1280 won't cut. Can I get a new blade?
The parts list doesn't show a blade alone, part # LN6775001 is the cutter lever, could be what you need. About $3.00
Jun 23, 2009 | Brother P-Touch - PT-1280 - Home and...
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Lost instruction manual brother pt-1000 label maker
Many Thanks. I down loaded the instruction manual then noticed that there are brief instructions on the back of unit.
Jun 23, 2008 | Brother PT-1000 Thermal Label Printer
Brother PT-1000 Thermal Label Printer Logo
135 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
