Question about Electrolux E23CS75DSS Stainless Steel
Electrolux E23CS75DSS Noise
Hi, I recently purchased an Electrolux E23CS75DSS side by side stainless steel refrigerator. About once per hour, it makes lots of noise. The repair man told me that it is because it is forcing freon through a small pipe and that these new fridge make lots of noise. It sounds like a constant gurgling / knocking noise. And it goes for about 2-3 minutes. I can hear it from 2 rooms away. Is this really normal? I read a review of this product where someone said it had quiet operation. But this is definately not quiet, it even woke me up in the middle of the night. Any help/thoughts much appreciated? Thanks, Andy
Hi Andy, I had a similar problem, when ever I opened my frezer door and closed it I would get a loud gurgling noise. I complained to the store where I purchased and they sent two repair people out with no luck. I finally conviced them to give me a new one, which does not have the gurgling noise at all. How ever this one does not defrost around the area where the ice comes through the door, frost builds up and I have to take out the ice box unit to defrost. These units look great but seem to have problems. Rich
Posted on Jul 29, 2007
    President:
  • 878 Answers
Hi Andy, I have had luck insulating the cap tube coming off the heat exchanger, going into the evaporator. If the repair man can wrap some mastic around the area where the cap goes into the evap, this may quiet it down enough. This is common on some models. Some people are more in tune to it than others. Give that a try. Catriver.
Posted on Jun 16, 2007
SOURCE:
The tab that you push to dispense water snapped and is just hanging there. Can I fix this myself?
Good Afternoon Cecilia Soares, thank you for your inquiry!
From the information you have provided the dispenser tab on your Electrolux refrigerator has snapped and you would like to repair it. I am unsure if it is repairable you may need to order the replacement part for your refrigerator. Based off the model number, E23CS75DSS, I have located a parts manual this should help you locate which part may be needed. I hope this information is helpful. -Matt
Frigidaire Manual Search Results
Feb 13, 2015 | Electrolux E23CS75DSS Stainless Steel
Finger print proof coating on outside bubbling up, any way to fix?
Hey friend, thank you for your post!
You are able to purchase parts with the coating already applied for your Electrolux refrigerator, E23CS75DSS. To answer your question, there is no way to fix the bubbling issue on your appliance you would have to purchase new parts for your refrigerator. I have included the parts manual link so you can look over parts needed. Once you have those parts numbers needed you can reach out to the manufacture to order them. I hope this is helpful. -Matt
Aug 13, 2014 | Electrolux E23CS75DSS Stainless Steel
Water is not working.
Hi
Please check this link bellow to troubleshoot your problem:-
http://www.ehow.com/how_2306100_fix-refrigerator-water-dispenser.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Electrolux E23CS75DSS Stainless Steel
Freezer working fridge not cooling?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 29, 2010 | Electrolux E23CS75DSS Stainless Steel
Fridge not keeping cold..
Check the coils underneath the fridge. Carefully vacuum and brush the coils clean. Usually there is a condenser fan near the compressor and condenser and a evaporator fan in the freezer. Make sure they both are turning.
Jun 21, 2010 | Electrolux E23CS75DSS Stainless Steel
Ice dispenser not working
HI THE ICE MAKER IS NOT DISPENSING ICE NOT WATER
May 30, 2010 | Electrolux E23CS75DSS Stainless Steel
Water dispenser leak all the time how can i fix it?
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
May 10, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The water door panel doesnt work. Incl. the light, ice. It doesnt even light up when the buttons are pushed.
Did you ever find a solution? mine has the same problem and I appreciate if you can share your solution.
Oct 16, 2009 | Electrolux E23CS75DSS Stainless Steel
Electrolux icon Stainless Steel Temperature issue
ok you have a defrost problem the freezer does all the cooling for all the unit both sides give me a few and ill give you the procedure for finding out which part needs to be replaced
Feb 20, 2008 | Electrolux E23CS75DSS Stainless Steel
Electrolux E23CS75DSS Stainless Steel Logo
879 people viewed this question
Top Electrolux Refrigerators Experts
Marvin
Marvin
Sal De
Jose Pino
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
