Question about Dell Dimension 4600 PC Desktop
Not connecting to Internet
Dell 4600, integerated LAN connection. I tried a new cable nothing changed. I connected a different computer to the Hughes Sat modem and the LAN light on the modem light up and I connected to the Internet OK. I used the old and new cables with the second computer and both worked OK.
With the Dell, the LAN light on the modem did not come on.
What or how can i replace/by-pass the integerated LAN on the dell?
  • 623 Answers
It is really rare, but it happens that the NIC (Network Interface Card) dies. Fortunately that is not a big deal, since you can buy one very cheap at your local computer store. or here.
(Don't let them sell you a Gigabit Ethernet card, that would be overkill. A 10/100 Mbps will just do fine!)
First - if you don't have one - download a manual here.
Look at page 55 onward how to open your computer and how to add a card to the PCI slot.
This is not complicated at all, even if you have never done this.
Just make sure that you unplugged the power cord before you start.
Try not to touch anything on the motherboard or the golden contacts on the card. (Hold it on the plastic side.) Make sure it is sitting tight in the slot - push it gently down.
If you run into any trouble, just come back here and I am happy to guide you through the process.
Posted on Jan 15, 2009
  • 71 Answers
You will need to get a wireless router
  • 54 Answers
The Nic on the main board sounds like it went bad. You can purchase a pci nic card at best buy or so install that and it should be good to go.
Lan cable not connected
Try re-connecting the LAN cable to your computer and the model/router/
If this does not work the try a different LAN cable - the cable could be faulty.
May 02, 2012 | Sony VAIO E Series VPCEB36GX/BJ Notebook
My netgear wireless-N 300 modem router dgn2200
Apr 11, 2012 | NetGear Computers & Internet
I have a computer that can not connect to the internet or do a tracert to any address can some one help
Check your LAN card,whether it is working or not.Then check that drivers are installed on the system of the following LAN card and restart your system
Also check the LAN cable and attach it properly
May 11, 2010 | Dell Dimension 4600 PC Desktop
No LAN connection on Dell 4600 series
Go here - - copy and paste this address into your browser window -
you must enter your pc's tag number - - otherwise you won't get what you need.:
either copy and paste the link below or right click it and choose open in new window
This will get you there - you will need to slow down - read and think - but only you know what your pc numbers are so grab a friend to write the numbers down and you will find success
Mar 31, 2010 | Dell Dimension 4600 PC Desktop
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
Lose internet connection (hughes net) when hooking up router
I would contact your hughes net, that is a satelite provider. That is a total different system, than dsl or cable. Hughes net should be able to walk you through the setup.
Oct 26, 2009 | Linksys WRT160N Wireless Router
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
I have a dell dimension 4600 which is having intermitent problems connecting to the internet via a hardwire connection to a verizon fios wireless router. The router works fine with my dell laptop both when...
I assumed you adapted the pc with a device for wireless connection ..if all the other are OK ..the problem is this device ......try it on other computer ..if it works ..its just a compatibility issue ..if not its a problem with it ...
also try to change the freqvency they work in ..if it possible ....or change the position ..cause they work on a radio wave and you might interfere with something when it goes out of signal ...
Jun 16, 2009 | Dell Dimension 4600 PC Desktop
Cannot connect to my Netgear WRG614 v6 Router. My Dell laptop shows an excellent connection but it says limited or no conectivity? I have tried several suggestions and reseting several times...nothing...
If you are using LAN cable from your ISP. Try to connect it to your Computer LAN port directly or how you connect directly your internet connection from your computer without the router. Then on your system tray try to look the internet icon activity usually a two monitor icon. Right click on there. Then select status,then support, then details, from there see the DNS number you may get two DNS numbers set then put that manually to your wireless lan settings.
Jun 06, 2009 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
87 people viewed this question
Alun Cox
