Question about GE 24 in. GSD2220Z Built-in Dishwasher
GE GSD222oz dishwahser
Once the water has filled and wash cylce begin, water is leaking underneath, dripps off plastic assembly behind the pump. I am not sure if it is the pump or the housing.
  • Anonymous Oct 29, 2008
    water leaks from the bottom of the dishwasher every time i use it.
  • 87 Answers
You need new pump seal. Will need to pull dishwasher and pull motor/pump
Posted on Jun 17, 2007
Tip
The washing machine is leaking all the time?
The possibilities for this problem are mentioned as follows:-- Check the water filling hoses which lets the water inside the washing machine while filling. There are two fill hoses.one for cold water filling or one for hot water filling.if this hoses are worn out or cracked the washer will leak.so both the hoses needs to be checked and replaced. But if the hoses are checked OK then other possibility is the tub seals on the tub.The seal can be seen between the transmission assembly and outer tub assembly of the washing machine. If the tub seal is got loose or worn out it needs to be checked and replaced. But if the tub seals are proper and not worn out then other possibility to check out is the drain pump.Check if the pump is got cracked ,loose or worn out.in case or cracked or worn out it needs replacement but if its loose you can just refit it properly to stop the leaking.But if the pump is not leaking and it looks properly fit then other possibility to check is the outer tub assembly.its made up of plastic and this plastic gets cracked after certain period of time.or if any pointed object/material if remain in the clothes while washing .then due to that pointed object there becomes a hole in the plastic outer tub assembly .This all the possibilities.that has to be checked. This will help.Thanks.
on Mar 18, 2010 | Washing Machines
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
While i'm washing water is getting on my floor, I don't know if it is when spinning or washing what could be the problem?
Help me help you...Dry the floor...Set the load size to small. Let it fill and start the wash cycle. Stop the unit. Look underneath it. Is there water on the floor? If so let me know. If not, start it up again and let it complete the wash cycle. As it begins to drain, look for water on the floor. Let me know.
I am trying to help you eliminate (or isolate) a bad tub seal, centrifigual force out, or a drain pump issue. When the water actually begins to leak is the key element we need to know in order to solve your problem. :) 2CR
Jul 31, 2009 | GE WJSR4160DWW Top Load Washer
WATER RUNNING FROM THE BOTTOM OF MY DISHWASHER AFTER THE FIRST CYCLE
Since if did not begin to leak during the DW filling, we can rule out the inlet hose and solenoid valve.
When water leaks from underneath and not from the door, the most common failure is the seal between the DW tub and the wash pump/motor. Replacing that assembly would be the way to repair that problem.
The other possibility is that you have a rusted or broken tub enclosure which is leaking directly through the bottom. Replacing the dishwasher would be your best option then.
Good Luck!
May 07, 2009 | Dishwashers
Occasionally it will overfill
The water level switch is your problem.
Open the control panel and remove the plastic hose from the level switch and blow through it.
Soap and dirt clog the bottom end and prevents the switch from stopping. The water continues to flow because of this blockage.
After you reattach the plastic hose , set the washer to spin and turn it on to reset the switch.
Mar 15, 2009 | GE WBSR3140DW Top Load Washer
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Kenmore Washing Machine
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
GE 24 in. GSD2220Z Built-in Dishwasher Logo
227 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
