Most TVs have a 1 year warranty. You will need to check the exact purchase date if you are near the one-year date. If you are still covered by that one year warranty contact Sanyo promptly. The number to call is 1-800-877-5032; you will need to have the model number and serial number for your TV to get warranty service.
The one year warranty exists on the FVM5082 and the DP50747.
I hope this helps.
(if you purchased an extended warranty, consult your paperwork for that service.)
SOURCE: Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... [email protected]
SOURCE: 50 inch Sanyo Vizon Plasma TV. Has sound but no
This set has LG insides, it will have failed on either the Y-Sustain PCB or the Z-Sustain PCB.
Quite common.
Repair estimates should be $250 - £350 depending on which has failed.
Stick it on eBay, it will fetch good money faulty.
Testimonial: "Thank you for your response. We were driving ourselves nuts - fuzes checked out fine and not other guess where to turn. We appreciate your help!"
SOURCE: hi i have a 50 inch sanyo plasma tv...all of a
Usually a power issus are a power suppy issue or main board issue. If unit or pilot lights do not light happens.
SOURCE: Sanyo TV LCD 32 inch about 3 years old. No
the power supply of your tv is bad try to check the fuses if fuse are open try to replace them with the same value..try to power it on but if the fuse blows again replace the power supply board...
good luck plse rate my help.
