Question about Lexmark C522n Laser Printer
Error 34: Incorrect Media
Lexmark C522n
  • Gary
    Gary Jan 16, 2009
    Found the solution on my own.
    Paper type was set for "Transparency" and should have been set for "Plain"
    Reset on the printers control panel under Paper Handling and it works great again !
    Novelist:
  • Lexmark Expert
  • 297 Answers
Someone had set the paper type to "Transparency". I reset the paper type back to "Plain" and the printer started working again !
Posted on Jan 16, 2009
I have a Lexmark C522 printer and it has come up with an error : 140.01 Service Motor Error. What does this mean and is it repairable?
Please click on the link http://bit.ly/pABOH4 to see instructions on how to go about the procedure
For further assistance, please contact Lexmark Technical Support.
Jul 18, 2011 | Lexmark C522n Laser Printer
My lexmark is giving oerro 83 it is a C522
Error 83 indicates a problem referring to the transferbelt. Order a replacement transfer belt. When print quality is reduced, installthe new transfer belt using the instruction sheet that comes with the replacementtransfer belt. For further assistance, please contact LexmarkTechnical Support.
May 10, 2011 | Lexmark C522n Laser Printer
Replaced ink with #32 & #33 but keeps saying right & left ink cartridges incorrect. please help
The Lexmark X3550 cartridges are:
Black: #23, #23A, and #34 Color: #24 , #24A and #35
I hope this explains why you are getting the error. Thanks.
Feb 16, 2011 | Lexmark X3550 All-In-One Printer
I have 111.05 print head service problem,
This error message pertains to an issue with theprinter's laser assembly 1Power off the printer and disconnect the power cordfrom the outlet. 2 Wait at least 30 seconds. If possible, plug thepower cord directly into a grounded wall outlet. 3 Power on the printer to see if the error clears. 4 If the error remains, contact Lexmark for additionalassistance.
Feb 07, 2011 | Lexmark C522n Laser Printer
Lexmark c522 service error 120.10 new fuser unit fitted
Please go to the www.lexmark.com website. Select Technial Support, enter the model of the printer. On the next search screen type in this ID ENUS26869.
Don
Jun 30, 2009 | Lexmark C522n Laser Printer
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Blue smudges on left edge of paper every 2-3 inches. no problems with other colors
I have the hp officejet 6310 all-in-one and have lexmark x73 cd and when i in stall it i can not scan it gives me a error of not connect to computer
Mar 26, 2009 | Lexmark C522n Laser Printer
Lexmark C522n Laser Printer stating "83 replace transfer belt"
how do you reset the transfer belt of a Lexmark C522 colourlaserjet.
Thanks
Alex
Mar 18, 2009 | Lexmark C522n Laser Printer
34 incorrect media
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Dec 18, 2007 | Lexmark C510 Laser Printer
Lexmark C522n Laser Printer Logo
157 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
