Question about Toshiba TLP-380, TLP-780, TLP-781UF Projector Lamp - TLP-L78 Projector Lamp
Showing to of the same thing twice and colors
I have a toshiba TLP 380 projector, the words are showing up double causeing a blur also i got green and pink colors showing up on the screen any help o advice would be a big help thanks
The projector has one or more "burnt" polarizers, more than likely.
They are replaceable, but expensive if you buy them from the manufacturer.
Look on Google for "burnt polarizer".
It's not the easiest job, but at least they're replaceable.
Posted on Jan 27, 2009
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
When I project, the display on the wall is green, can't figure out why. Is it the INPUT into the projector?
i have lcd projector but problem to connect dell vostro 1510 only not show laptop. only show lcd projector but without show laptop. i need both laptop show and lcd projector how explain me.thank
Apr 27, 2010 | Toshiba TLP S30 Multimedia Projector
Green color on screen
Take out the up cover of the projector. Make sure all the screws are tight. Actually take out the main board and replace it again... That should do it. Otherwise there is a problem at your main board.
Feb 28, 2010 | Toshiba TLP-XC2500AU Projector
I have a Toshiba TLP-S30 and lately the color balance of the projected image is way off. I've tried adjusting the color balance via the menu, but no improvement. Could this problem be fixed with a new...
reset the settings to factory default. sometimes the lamp will burn at a lower temp at the end of it's life and emits a different color. might be the lamp or the ballast. if all else fails, replace the main board.
Oct 18, 2009 | Toshiba TLP S30 Multimedia Projector
My toshiba tlp710 projector wont power on
check your power cord first, if good, if not replace it. if the problem still occur, check the power supply board of your projector. and replce it.
jahting
Oct 08, 2009 | Toshiba TLP-710, TLP-711, TLP-G5, TLP-G7...
White areas in the image are yellow and the black are blue-green
you have a few issues. first is the yellow in white. the light filter on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you may have to replace the whole optical engine. as for the flashing horizontal lines, the power supply isn't cooling down and the caps are drying out, causing fluctuations in voltage. so, replace the power supply.
Jul 04, 2009 | Toshiba TLP S30 Multimedia Projector
Toshiba with Colour fail , red colour
the filter lense of color red had discolored
Feb 04, 2009 | Toshiba TLP 260 Multimedia Projector
Showing to of the same thing and colors
ghosting or convergance issue is what u have. if the image is in diff colors then deff a convergence issue. however, if the image isthe same color or shaded from the original then this is ghosting. this may be corrected through the menu settings(sinc settings).
Jan 15, 2009 | Toshiba TLP-380, TLP-780, TLP-781UF...
Problem with image from LCD
No, If the problem comes with connecting the signal, then it could be RGB.
if this is coming with all time then check LCD panels and Fly-eye lens.
Last thing is lamp unit.
viren
Sep 19, 2008 | Toshiba TLP-S10 Multimedia Projector
LCD Toshiba TLP s10
You probably have the input set to component video (Y/Pb/Pr) which will distort the colors
Oct 23, 2007 | Hitachi CP-X270 Multimedia Projector
214 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
