Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I cant find the filter on the hotpoint aquarius wd440
I dont have a clue where the filter is on the wash and dry machine does enybody know where it is ?
  • Hotpoint Master
  • 3,463 Answers
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
  • emmahume9 Aug 21, 2011
    how do you take off the clip from the hose? do you need a special tool?
    thanks
  • Barry Coates
    Barry Coates Aug 21, 2011
    Hi.
    Depends on type of clip fitted.
    On some washers there is a clip called a corbin clip, for which you need a pair of corbin pliers, but it can be removed with a pair of mole grips, again, it depends on which type of clip is fitted.
    You will have to use your judgement.
SOURCE:
Hello, i am using Haier washer dryer HWD-D1200TXVE that is 1 year old, after a full cycle (pre-wash) the machine gave an error 12 and did not perform drying because water was not drained. I opened the...
Look up the mfg website and see if they have a troubleshooting page or a support group. It may still be a warranty item check that as well
Oct 20, 2013 | Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
Aqaurius wdl520 drier not drying dont know how to open filter
There is no filter - besides the lint trap on this dryer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 31, 2009 | Washing Machines
Too much water
Most likely your water pump is blocked. I don't know where to find a parts brake down for this, as this model is not listed over here across the pond, but from the photo I found it appears that there may be an access door to a filter on the lower right side of the machine.
Sep 17, 2008 | Whirlpool AWM5145/2 Front Load Washer
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Help with whirlpool awm 8103/1
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
1,006 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
