Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Rabbit eats video cable....
How do I get the back off to fit a new cable - and where can I obtain one!
  • 38 Answers
That is a dificult task to find a new one, unless you have a broken one you want to take apart they are not a standard cable. Your best bet is to go to an electronics store and buy a new plug to solder onto what is left ofthe cable. To find the pinout, just use a digital multimeter and test the continuity of the pin to the color of wire on the other end. Then just find yourself a VGA extension cable.
Posted on Jan 15, 2009
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
Apr 25, 2017 | Vizio Televison & Video
What do panthers eat like what do panthers eat in the wild
The exact answer depends on whether you mean the North American puma, or the South American jaguar.
They are both meat eaters primarily, so they would eat small and large rodents, rabbits, deer, pigs, domestic pets, and birds and fish if they can get them.
Feb 21, 2017 | Sport & Outdoor - Others
What do red foxes eat? do they eat fruit?
The red fox eats a wide variety of foods. It is an omnivore and its diet includes fruits, berries and grasses. It also eats birds and small mammals like squirrels, rabbits and mice. A large part of the red fox's diet is made up invertebrates like crickets, caterpillars, grasshoppers, beetles and crayfish Red Fox Vulpes vulpes
May 17, 2015 | Cars & Trucks
What do cheetahs like to eat
n general, the diet of the cheetah consists of gazelles, wildebeest calves, impalas, and smaller hoofed animals in its habitat. Furthermore, cheetahs may eat rabbits, birds, hares, antelopes, and warthogs.6 Feb 2014
Cheetah Facts - About Cheetahs - What Do Cheetahs Eat? Where Do ...
www.conservationinstitute.org/cheetah-facts/
Mar 13, 2014 | Fish
Can rabbits eat bamboo
Rabbits can eat whatever they want....Sorry, just a bit punchy. Rabbits are fine to eat untreated bamboo, it is just a grass. By untreated I mean bamboo that was not used for furniture. Just the raw fresh or dried bamboo is fine. There are several hutch enclosures made of bamboo that they love chewing on.
Oct 10, 2012 | wikipedia.org
How do you change a positve battery cable on a 1998 dodge avenger car?
First a little more clarification would be helpful in, Why do you think the cable needs replaced? If the cable is corroded at terminal connection a new connection fitting is much more simpler than cable replacement. Nonetheless, remove the negative battery cable first, then the positive. (1)Clean the corroded area's with baking soda and water mixture (you should wear eye and hand protection- battery acid will eat through clothing in a matter of minutes).Scrub gently with nylon brush -using a wire brush can cause sparks and may cause a fire from hydrogen gas escaping form battery. Flush with clean water and your ready to start the next process. (2)Assuming you will adding a new terminal connection fitting - cut off bad fitting with wire cutters or hack saw, skin back wire about ONE inch and install new cable fitting.(3) install / reconnect battery. (4) Your cars computer will be cleared of all learned shifting patterns and other feedback information. It will revert back to factory preprogrammed settings. Average cost of replacement cable clamp $3.50. New cable cost to starter +$30.00
Happy motoring.
Jan 03, 2011 | 1998 Dodge Avenger
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
48 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
