Question about Ovens
Magic Chef model 68HA-4TVW -Fault code f3 Oven won't heat
We assume it is the temperature sensor,but we removed it and we still get the same error, and the fan continues to run. Oven will not heat.
This is an electric oven. Don't know how old oven is. Want to make sure it is not another problem before we order parts.
5 Suggested Answers
  • 183 Answers
SOURCE: Magic Chef Oven lights and shuts off
This could be caused by a lack of air within the oven cavity, once the air is used up the flame will go out, it will then work again once it is relite, but will probably do the same again, this could be dangerous and requires on site proffesional attention. Regards Engineer
Posted on Jul 28, 2007
SOURCE: GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Posted on Sep 24, 2007
bigg t
  • 640 Answers
SOURCE: Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Posted on Sep 29, 2007
SOURCE: Magic chef oven won`t heat
I can not get ovento work it will work if I have it on manuall but I cn not get if off aut It is a Chef Constellation Delux We have just brough this hopuse and thwere is no manuall to operate
Rwegards Fay
Posted on Apr 22, 2008
  • 217 Answers
SOURCE: f3, f1 error mesage on magic chef stove, oven not working
http://www.applianceblog.com/mainforums/showthread.php?t=7643 click this link
Posted on Nov 30, 2008
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
I am looking for a manual for an electric oven,
The owners manual is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/59F-5TXW.pdf
Fault codes:
F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace
New Sensor is here:
http://www.appliancepartspros.com/part_details.aspx?part_id=4009009
Low price too!
The F2 will appear because the sensor is not controlling the temp so the high limit thermostat is being tripped.
Thanks for using FixYa.
Kelly
Mar 26, 2010 | Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
Ovens Logo
105 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Oven Expert? Answer questions, earn points and help others
