Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
First color alignment problems then no pix or sound, just chirpin
We had our rear projection phillips tv (60pp920217f) fixed about a year ago. The second repairman said the first repair man didn’t put enough grease to insulate it so it overheated. The second guy couldn’t get the red in the left corner to go away so it looked like a little rainbow in the corner after he was done. He said he worked on the lsb board, convergence chips and resistors. The very next day it wouldn’t turn on. No picture or sound, just chirping. We called him but he refused to come back and check on it and said he was out of business. We would like to know if what he worked on could have caused our problem now or if he could of made a mistake and shorted something out? We live in a small town and it is very hard to find someone to work on these TV’s. We’d appreciate any help you could give us.
  • khale Jan 17, 2009
    Thanks so much
    Scholar:
  • 87 Answers
If the unit is chirping your convergence amps are out again,or you have a shorted Horzontal output transistor. Not likley for horz output to go out after convergence repair. If he did not replace the 6.8 ohm resistors along with the convergence amps the convergence amps would overheat and short out again.This would explain why the corner would not adjust out. Not a very good buisness practice on his part.Here today gone tomorrow?
Posted on Jan 15, 2009
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
The picture on my phillips rear projection tv is red and I can't change it by adjusting colors. What is wrong and how can I fix it?
Tv have colors lines R,G,B mis alignment any colors,shadows colors, 3D pictures,the tv have a problems known as a convergence problems.The tv convergence board is dead.The 2 STK Convergence ICS and some or all it resistors are dead too.Must replaced these parts to solved convergence problems.The shop will cost $300-350 for parts and labors.
Aug 05, 2010 | Philips Magnavox 51MP392H Rear Projection...
I have a Phillips Magnavox HD Tv Rear Projection Television and the picture looks greenish and reddish and is blurry on the text of the screen? please help.
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 03, 2010 | Philips Magnavox 51MP392H Rear Projection...
Phillips 43" T.V sound is fine Picture is Faded? Still visible but very light and faded..How do I fix
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 06, 2009 | Philips 43PP9202 43" Rear Projection...
My rear projection television looks like it is 3D
replace the lamps and then run the synch routine from the main menu. unfortunitly with the expense of the lamps and the low price to replace projection tvs it might not be worthwhile to fix but just replace.
HINT wait till after new years, LCD large screen tv sold about 35% of what was expected during xmas so they will be real real cheap after the 1st of the year
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Broken Screen Phillips 60PP920217F
go to phillips.com/parts they should have them there
Aug 31, 2008 | Philips 60PP9202 60" Rear Projection...
PHILLIPS BIG SCREEN TV IS BUTTERFLIED
Are the colors out of alignment and unable to converge back? If so its the convergence ICs need replacing. If the convergence isnt out of alignment you have whats called a pincushion problem. If you would like a link to where you can obtain the service manual for this model let me know.
Mar 17, 2008 | Televison & Video
Phillips Magnavox Rear Projection Tv screen too dark
The high voltage is failing. The LSB board is about $200 from partstore.com.
Dec 28, 2007 | Philips Magnavox 51MP392H Rear Projection...
Phillips 60PP920217F bows in on top and bottom
convergance amp ic are bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 28, 2007 | Philips 60PP9202 60" Rear Projection...
BIG TROUBLE with my 52" Phillips Magnavox Rear Projection Tv, HELP!!
It sounds like the 3 "GUNS" are not aligned.
One the controls at the bottom, left hand side You will see an arrow pointing to the first 2 on the left.
That will allow you to scroll down the list of options until you see....CONVERGANCE!
make the red gun center by using the up/down arrows on right. Then add the next 2 until you see a white X or cross.
Thats it!
Mike
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
