Question about Thermador SEC301 Electric Single Oven
Heating elements do not heat
I have a single, built-in electric Thermador oven, Model No. X301XP, Serial No. 99070550. Neither the oven or the broiler works. Have I blown a thermostat or internal fuse? There does not seem to be any obvious problem externally with either of the heating elements.
  • 35 Answers
This problem your having is some connected with your oven shut down thermostat.if that does not solve your prob.next solution would be to check that control board.
Posted on Jun 25, 2007
  • 175 Answers
It sounds as if you have a tripped thermal cut out. This is accessed by removing the 5 or so screws on the black grate below the control panel and pulling the grate out. Somewhere in the middle towrds the front should be a little button wiht 2 wires hooked to it. make sure you have the power off to the oven, then reach in with a screwdriver or your hand if you can and push the little red buttton down untill it clicks. The cause for this to trip could be bent door hinges not allowing the door to close fully (common thermadore problem), bad door gasket especially in combination with running a self clean cycle, broiling with the door ajar, or a bad cooling fan (the one behind the electronics, not the one in the oven) Hope this helps.
Posted on Jun 18, 2007
SOURCE:
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Thermador over/microwave/heating drawer model SMW272YP Bake bottom element will not heat up. I have replaced the element. The display pannel has been replaced in the past, but still keep having the same...
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Mar 07, 2009 | Thermador C302U Electric Double Oven
Heating Elements for oven and broiler do not heat
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Jun 16, 2007 | Thermador SEC301 Electric Single Oven
Thermador SEC301 Electric Single Oven Logo
302 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Thermador Oven Expert? Answer questions, earn points and help others
