Useing PC 102rf brothe ribbon film in a brother fax 575
I had an older brother fax machine that died, and I have 2 rolls of new replacement ribbon/film.
Can I use the older film in my newer machine? and if it is larger, just be removing enough film from the rolls, to insure it turns in the smaller cartridge?
What is your take on this.
(Never throw anything away, there might be a use for it)
New machine is a fax-575 Brother
Old machine was an intellefax 1250
I was told it no can do, or be done- whatever! I am not finished yet, that is a challenge!!
Posted on Jan 16, 2009
Ribbon is empty in fax machine 575 what to do
Check if the thermal ribbon (ink) is finished . Open up the front panel and you will see the black film roll .
Sep 11, 2014 | Brother FAX-575 Plain Paper Thermal
How do I reset the Ribbon?
you don't reset the ribbon .. you have to replace it. it is called a thermal ribbon part number is Brother PC-501, or PC501 you can get it at office max or office depot or staples or Precision Roller for about $28.00
Apr 12, 2014 | Brother FAX-575 Plain Paper Thermal
It says ribbon needs to be replaced or reset can i just reset and still use that ribbon
i got a new ribbon and it keeps saying ribbon empty reset or replace. i unplugged it for 30 seconds didnt do any good how can i fix this? it is a brand new ribbon
Jun 17, 2011 | Brother FAX-575 Plain Paper Thermal
HOW DO I CHANGE THE RIBBON?
You can use the below link that will take you to the brother FAQ website. Follow the FAQ to change the ribbon.
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000500/000045/faq000545_001.html?reg=us&c=ca&lang=en&prod=fax575_us&Cat=7
Thanks,
Pat
May 13, 2010 | Brother FAX-575 Plain Paper Thermal
I have a brother 575 and when i would make copies, the film would come out attached to the paper that was copied. well. I opened it up and one of the wheels fell out of somewhere. I can not figure out...
Search inside the machine by opening the latch on the right side. Be sure to unplug, as it may be hot. Pull out the film cartridge and look for the missing wheel. Remove and order a replacement cartridge. Shop because prices vary greatly. You can order replacement film rolls or the entire cartridge. In your case, i would go for the entire cartridge. You can find them for under $15.
May 05, 2009 | Brother FAX-575 Plain Paper Thermal
I have a Brother Fax-575 that needs ribbon replaced. Can I use a compatible brand which indicates that it meets mfg OEM standards or should I stick with Genuine Brother?
A compatible should be fine. Some of the new Brother laser machines can actually be broken by non-OEM toners, but yours is not a laser. The worst I'd expect from a donor film might be a slightly poorer image. Try it out. If you have to load the film rolls into your old cartridge, make sure it's running the right direction, and with the correct side down.
Feb 26, 2009 | Brother FAX-575 Plain Paper Thermal
Can I reset the used ribbon to recieve a fax ready to print
You can rewind the ribbon. But the areas that has ben transferred from past fax's will be blank.
Jan 28, 2009 | Brother FAX-575 Plain Paper Thermal
Cartidge jams when trying to print a fax
I use to sell the generic ribbons. they have a lower heat transfer. the ribbon starts melting to the paper & causing all kineds of problums. Sorry to say you need to buy name brand.
Oct 10, 2008 | Brother FAX-575 Plain Paper Thermal
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
59 people viewed this question
k24674
jasbo
jasbo
