Question about GE JEM31 Microwave Oven
About that burned microwave
The link you provided doesn't work.
  • mpattock Jan 15, 2009
    Still doesn't work. What is the exact URL?
  • 716 Answers
Sorry Let Me Try It Again Click Here To Order Parts From Ge.
Posted on Jan 15, 2009
  • Michael Fisher
    Michael Fisher Jan 15, 2009
    It Works When I Click It But I Guess You Can Copy And Paste It.
    http://www.myapstore.com/Omega/Dispatche...
XL1800 buzzes but heats
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor too. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
May 11, 2013 | GE XL1800 1100 Watts Microwave Oven
GE JVM1630 makes a humming noise and doesn't get hot
It may be a shorted high voltage diode or a failing magnetron.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.microtechfactoryservice.com/microtech/mag_test.html
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Apr 16, 2013 | GE JVM1630 Microwave Oven
Plate in microwave doesn't go around anymore
it burned out the only option is to replace the motor- you can check to make sure its burned out by removing it(the motor) and giving it 110 volts, if it spins then you have another issue, if not then its burned out, you can try and take one from another microwave but sometime they are custom fit, just be sure to check the voltages are the samegood luck questions just ask
Mar 30, 2013 | Magic Chef Microwave Ovens
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
I have a combination oven and microwave model # J KP86BOF1BB manufactured Nov 2002. For about a week there was a slight burning rubber smell when using the microwave and now it does not heat anything. The...
It's probably the magnetron which some companies provide an 8 year warranty on for parts but you'd be responsible for labor. Unless you have an extended warranty, it's probably cheaper to buy a new one than to repair this one. I tried to look up your model number but doesn't seem accurate. Do a little research, there could be a known defect and the company may help even though it's out of warranty.
Nov 19, 2012 | Microwave Ovens
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
Sharp micro doesn't heat
see this causes and fix it. God bless you
Oct 02, 2012 | Sharp Microwave Ovens
Maytag microwave problem everything seemingly works but does not heat. Help
Oct 01, 2012 | Maytag MMV4205 Microwave Oven
Heating problem
Sep 27, 2012 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
GE JEM31 Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
