Question about Thermador SEC301 Electric Single Oven
Heating Elements for oven and broiler do not heat
I have a Thermador X301XP single built-in electric oven. In fact, I have two separately installed. I have checked breaker and power to over and all other function seems to work except I cannot get the oven to heat up. When I set the oven to preheat, it will not heat. When I tried the broiler, it will not heat. What is wrong? Is the thermostat bad or is there an internal fuse?
  • 3 Answers
There is four crimp connectors on the inside at the element. They can go open circuit. I would check them. There is an interna thermal fuse, when the element blows that usually goes too. Good luck
Posted on Jun 16, 2007
SOURCE:
How do I turn off f13 beeping
For most codes, Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on.
Nov 27, 2014 | Thermador C301U Electric Single Oven
Everytime I try to push the sensor for bake, broil, or convection and "off" light up in the clock window and nothing happens. This is a thermador built in oven modelSMW272ZP. Any ideas why it started doing...
Hi, Check fuses on the stove. Check the breaker panel for correct breaker and if breaker has tripped.
Then you will have to ask a technision to look at it further. Good luck
Mar 17, 2014 | Thermador SMW272 Electric Double Oven
Broiler element doesn't heat
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Feb 09, 2014 | Thermador SEC301 Electric Single Oven
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
Pre heat works on smw 272 yw but oven or broiler do not heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';';
Sep 22, 2011 | Thermador SMW272 Electric Double Oven
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
Oven will not heat up broiler works. its a thermador rdss oven
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Fan works, but Oven stays at 100 degrees. Tried
I had the same problem in December - I had to replace the circuit breaker and that solved the problem. My oven wouldn't go above 100 degrees in convection, bake and roast modes. Each of these modes are on a separate circuit so when one is bad, the others should work.
Jan 25, 2010 | Thermador C301U Electric Single Oven
Thermador SEC301 Electric Single Oven Logo
460 people viewed this question
Top Thermador Ovens Experts
Marvin
Marvin
Sal De
Are you a Thermador Oven Expert? Answer questions, earn points and help others
