Question about Teac PD-H303 3-Disc CD Changer
Teac PD-H303 CD Changer
The music jumps between tracks 6 to 9 on all three compartents it plays ok on all other tracks
  • 3 more comments
  • barry_patti Jan 16, 2009
    The cd is not scrathed and I also cleaned the cd
    Conections are ok and cd holders in correct postion
    Is this a expensive repair as it is out of warrenty
    I HAVE CLEANED THE PLAYER BUT THE DISC STILL JUMPS.
    Have removed cover but can not locate sled mechanism
    Genius:
  • 1,913 Answers
Reset all settigns to factory defaults.
Posted on Jan 16, 2009
  • 4,234 Answers
The problem here will require replacement parts. Welcomejee had posted one of the more common causes of this, but in reality, if the sled gears are clear and in good shape, the motor itself is the likely defective part. This is not a repalceable part from Teac. They will only provide the optical block which includes both the sled motor mechanism and the optics. This will make the parts cost more than the replacement in all probability.
One thing you can try to prive this is to alter the position of the sled in relation to the motor position. Carefully move the sled along its path without moving the motor. WIthout seeing the specific mechanism inside your unit, I can't be any more descriptive, but the gaol here is to determine whether there is a problem with the motor or the mechanism. Because of how the motor is used, a slight "dead spot" inside the motor can cause the problem you are seeing. Basically it works like this:
The motor moves to a "center" position for the track and the lens itself is "tilted" to read the track behind, through the ahead of the exact motor position. When reading ahead, the electronics again tell the motor to move so that the "ahead" position becomes the "behind" position for the next read cycle. This means that the motor only moves a small bit. If a dead spot is hit, additional voltage is required to actually move the motor. When this happens, the motor can overshoot its target. The result of this overshoot is seen as skipping.
Hope this helps a bit.
Dan
    Sergeant:
  • 221 Answers
That could be some dirt on the laser head lenses.
Try cleaning the lens. If you can see the lens when you open it to put a cd in, you can clean the lens yourself with a q-tip. Use a very small amount of alcohol or windex, just enough to make the tip of the q-tip moist, and rub it on the glass lens in a circular motion. then use the dry end of the q-tip to dry it off. You can then try another cd and see if it plays good. If so, you are good to go, if not, you probably need a new laser pick up. If it needs a new laser, you may want to just buy a new boombox. The repair will most likely cost as much or more than a new boombox would.
----------the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out.
• Clean the disc.
• Check disc for warping, scratches, or
other damage.
• Check if something is causing the
system to vibrate. If so, move the
system.
• Make sure the speakers are at least 3
feet away or on a different surface
from the main unit.
  • 10,594 Answers
Please take off top cover and check Sled mechanism of Laser block, it has gears and grooves. I'm sure there would some dirt that obstructs smooth sled drive. Clean grooves and gear and then try.
Below is an image of optical block and sled mechanism is marked just to give you an idea.
If you need further info, please let me know.
Thank you.
  • Shahid Electronics
    Shahid Electronics Jan 16, 2009
    OK,
    I would recommend to take unit to local repair shop to clean and service common problem in CD player.
  • 535 Answers
U need to clan the your plyer lence u need a lance cleaner cd then try to play
    Guru:
  • 859 Answers
It doesn't matter which compartment, they rotate over to the read laser. The problem is in the chip that changes tracks. This is a warranty service problem.
I know that's the last you expect from a Fix It site, but sorry, you've got a bad chip.
Worldvet
  • Glenn Rogers
    Glenn Rogers Jan 16, 2009
    Expensive or not, the problem is in the chip not the gears or where the disc is in the tray. The tray just rotates into the the laser read component. The fact that each and ever CD is skipping the same tracks indicates the EEPROM (software written to a chip) is faulty. You cannot address this. I cannot address this, it needs a new chip. So, bad news is bad news. Sorry. We do have to give it now and then.
    Worldvet
    Scholar:
  • 160 Answers
Check out the connections first and also check the cd holder is it in correct position and also the scratches on the cd this can misread and lead to jumps.
    President:
  • 2,110 Answers
Cd might have some scratches on it...
THE MUSIC SYNCS ONTO THE DEVICE BUT WHEN I GO TO PLAY IT IT SAYS NO MUSIC FILE
You may need to factory reset it. Once it's blank, try syncing it again but with just a couple of tracks you know play OK.
Jul 09, 2016 | Audio Players & Recorders
Downloading music from soundcloud
Some of the old soundcloud downloaders don't work anymore, so you have to try some new solutions. There are many websites that allow you to download the music from soundcloud easily, and also browser extensions for both chrome and firefox. It's difficult to download the tracks on your iphone or android but not impossible. There is a handy comprehensive guide here: How To Download Music From Soundcloud Tech Torpedo
Feb 14, 2013 | soundcloud.com
Denon CD deck
This unit needs a service visit. It may be a common problem with that model but to me it sound like a power supply issue as when you play a disc more power is used to rotate motors and move the sled. This is indicating to you that it is in a weakened condition and will soon fail more significantly. The problem may be as little as a solder joint or a defective Filter capacitor which is common in some models of equipment.
Dec 11, 2012 | Audio Players & Recorders
Display Panel
The problem is not with the display panel, it is with the changer mechanism. It may cycle through all five disc positions without playing a single one
Dec 03, 2012 | Teac PD-D2610 5-Disc CD Changer / Player
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
Price of it
Hello
The device you speifies here have a cost of 500 British Pounds.
For more details get into this website
www.stocktogo.co.uk/teac-pdh303-changer-hifi-separate-gold-p-1664.html - Cached
OK.
May 15, 2011 | Teac PD-H303 3-Disc CD Changer
Teac PD-H303 3-Disc CD Changer Logo
212 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
