Question about Lexmark Wheelwriter 6 Series II Typewriter
Need to reset all the margins on IBM Wheelwriter 10 Series II. The margin release button will not release the left margin.
  • Gary
    Gary May 11, 2010
    If you go to the right margin, does the margin release key work there? (Trying to see if keyboard is working)
    If it doesn't work on the right as well as the left, you need the keyboard replaced.
    If it does work on the right, you need to clean and oil the shafts that the carriage moves left and right on.
    If this model has a battery pack inside the ribbon area, take them out for 10 minutes with the machine off....then turn back on...(batteries store margins and tabs settings)
  • Lexmark Master
  • 3,594 Answers
The problem may be that the carrier is binding on return, put some light lube (WD40 works well) on the silver shaft that the carrier slides on.
DicktO
Posted on Jan 15, 2009
Change left margin on IBM wheelwriter 2000
To change the left margin, hit the return button which will take you to the left margin. Hit the margin release lever (mar rel) and then the backspace button to go farther to the left and stop where you want the margin to be. Hit left margin and that is where it will then be set.
May 09, 2014 | Lexmark Wheelwriter 3 Typewriter
How do I re-program my typewriter? the margins are too far in. IBM Wheelwriter 15 Series II
Go to the margin, press margin release, space or backspace to the desired location, press L. or R. margin.
DickyO
Dec 10, 2010 | IBM Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM personal Wheelwriter 2 margins not clearing
Return to the L. margin, touch the mar rel key top key on L. of the keyboard, backspace to location where you want the L. margin, touch the L. mar key. Put some WD40 on the silver shaft that the carrier slides on.
DickyO
Jun 24, 2009 | Lexmark Wheelwriter 5 Series II Typewriter
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Try a little light oil on the printer shaft. WD40 works well.
DickyO
May 13, 2008 | Lexmark Wheelwriter 10 Series II...
Margin Problems
You are in auto return. Press code and R
This should doit
DickyO
Mar 10, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 5 (Setting the Margin back to 5"
Sounds like you don't know how to set l. margin or you have some debris in the typewriter. Turn it off and see if the carrier will move back and forth by hand, if so turn it on 7 return to l. margin press mar rel key, backspace to where you want the margin and press l. margin key.
hope this helps
DickyO
Jan 15, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
MARGINS
Move carrier to left margin press margin release, top left hand side of keyboard, back space to desired position and press L Margin key.  Margins will reset to default if batteries are dead.   Right margin simply space to whever you want the margin and press R Margin.
Oct 24, 2007 | IBM Wheelwriter 30 Typewriter
Lexmark Wheelwriter 6 Series II Typewriter Logo
212 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
