Question about Kingston 4GB Secure Digital High Capacity Memory Card
KINGSTON 4GB MEMORY SD CARD
I PT THE CARD IN MY CAMERA AND IT SAYS MEMORY CARD ERROR WHAT DOES THAT MEAN???? I CAN'T EVEN TAKE ONE PICTURE I NEED HELP. THANKS
Card error in kingston sd card after taken picture. now in my card reader can't detact any picture...
Posted on Dec 27, 2009
  • 158 Answers
Check if your camera can support a 4G card. Some don't support than 2GB. if it supports, re-insert the card.
PS. If you have a card reader. Formatting once from your computer can help.
Posted on Jan 15, 2009
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
4gb kingston canon ixus 50
The IXUS 50 works with MMC and SD cards. Your new 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Jun 04, 2012 | Canon PowerShot SD400 / IXUS 50 Digital...
What size memory cards work with the Lumix DMCFZ20PP? I tried a 4GB and got a read error.
Hi
According to the information I have the maximum card size for the DMC-FZ20 is 1Gb SD.
Hope this helps
Dave
Jan 13, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
I put a new sd card in my camera and it says check sd card. It wont let me take pictures what does that mean
Your model camera can only use up to a 2GB standard SD cards, and not 4GB or higher SDHC cards. There are several other possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before the SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 02, 2011 | Samsung Digimax D53 Digital Camera
Hello sir, i have 4gb kingston digital memory card.And music are copied into it that is going on .but i am getting memory card error when memory card is in camera
Check the manuals of your Camera see if it supports up 4GB of Memory. Also note that some cameras can only take a particular kind of memory card confirm that your camera supports Kingston.
Oct 28, 2010 | Kingston 4GB Secure Digital High Capacity...
Drivers for detecting 4gb kingston SDHC
SD vs SDHC is a question I get alot. First let me explain your issue. Unless your CARD READER is rated for SDHC chances are its an older model and cant handle the card, even with driver updates. You will need to check the manufacturers website of the device you are using as a reader to see if there are newer drivers. If its a laptop go to the manufacturers page and and be sure and choose Windows XP as your OS. Ok, now to the difference. SD cards are called solid state memory. The internal workings of each hasnt changed much except that the SD card used standard file formatting that was understandable in Windows XP and earlier operating systems. the SDHC (HC stands for High Capacity) uses the same architecture in teh card but changes the way data is stored and read that enables it to hold more data on same size device. (note architecture means design of card type not inside guts) Thus your system and Operating system may not be capable of addressing the new coding and file system changes on teh SDHC cards. Many older cameras (2008 and before) dont recognize SDHC cards either. Good news is they make an SD card (plain) in a 4 gig and you may be able to replace yours at the retailer with teh correct one needed (unless you bought via ebay or other method) Yours is a good question and is often asked, so dont feel bad in anyway. Just look at it this way.. you learned the lesson recently when the pricing between the two is about the same.. I learned the lesson 2 years ago when an SDHC cost about 80$ compared to 19 $ for a normal SD... SMILE!
Jun 28, 2010 | Kingston 4GB Secure Digital High Capacity...
Card error
Your camera was designed (2004) and manufactured (mostly 2005) before current generation SDHC cards became available. It will therefore be incompatible at the basic hardware level. There were some non-standard SDHC cards around in 2006 but your camera was never designed for those either.
Stick to regular SD cards, in theory your camera can handle 4GB maximum but the design team wouldn't have been able to certify compliance with that size of card as they also weren't available at the time. To be safe, stick regular SD cards with a 2GB maximum capacity.
Sorry there's no way for you to use your SDHC with your present camera but at least I hop that I've prevented you from wasting time and money on buying another incorrect memory card.
Please return the favour by taking a moment to rate my answer.
Oct 06, 2009 | Acer CE-5330 Digital Camera
Memory card error
Hi michellefwon,
Try the card in your computer using a SDHC card reader to see if it will read your picture files. If that doesn't work then you'll have to shop for data recovery software on line. Ontrack Data Recovery is a very reputable recovery company. They offer recovery services by sending them your card or by purchasing their do-it-yourself software.
Their Website:
http://www.ontrackdatarecovery.com/
Kingston Tech Support
Jan 14, 2009 | Kingston 4GB Secure Digital High Capacity...
Memory card error
try formating.
but u may lose the data
also see that u format through sd utility available on sd.com
if still a issue than get free replacement by kingston as it has 5 yrs warranty
Jun 21, 2008 | Kingston flash memory card - 256 MB -...
Kingston 4GB Secure Digital High Capacity Memory Card Logo
232 people viewed this question
Top Kingston Electronics - Others Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
