I just reloaded the bobbin and retreaded the machine, when I start to sew all the stitch lights start blinking and the machine starts beeping and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Try changing the needle--make sure it's the right one for the fabric
being sewed
try changing the bobbin--make sure the bobbin is turned the right
way in the bobbin case
make sure the top thread has not come off the thread take up lever
here is a free manual if you don't have one, just click on the link
http://www.singerco.com/uploads/download/1198_8763-efs.pdf
SOURCE: Bobbin won't wind Singer 7422
Your problem lies with the main shaft that is to tight to release the bobbin winder mechanism, because of old grease and oil becoming sticky. A short term solution will be to remove the needle, in order not to hurt you, and then hold on to the needle bar with your left hand, while engaging the bobbin lever with your left hand. This will prevent the main shaft to rotate and your winder should work. In the long term, take it to your dealer to clean the oil and grease. You will not be able to open the machine casing yourselve, as you might damage the casing and or electronics.
SOURCE: Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
SOURCE: singer futura beeping every 8 stitches can you
Make sure your thread goes under the plate of the carrousel. If not the machine think is not threaded and it beeps. Thread the machine with your left hand and Pull the thread with your other hand to make sure it "clicks" to every part of the machine.
Another important detail is to add thread nets to your spool. After some used the tension of the machine is affected and the nets help the slippery thread to be pulled by the machine correctly and avoiding the beeping.
SOURCE: The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
