Question about KitchenAid KAWS850LE Top Load Washer
Washer will fill up with water and drain but will not spin or aggitate. the model is kitchenaid kawe677bwh1
My washer will fill up and drain but will not spin or agitate. In those cycles you can hear the motor run i think but therfee is no movement in the tub. i looked underneath and saw a belt but i cant seem to find the pulley. What do i do now? Thanks
  • 3 more comments
  • washerof5 Mar 09, 2008
    my kitchenaid washer kawe660wwh3 (15 years old) is not spinning and is making a loud noise as if trying to spin but can't. it has ***** been serviced before. the watered has drained out but all clothes are very wet. thank you for any input
  • annehume468 Dec 30, 2008
    I have an Asko washer that also will not spin or agitate. I thought it was because of a dime stuck in it but after reading what someone said about a broken coupler, I am not so sure. Please tell me how to best get inside it to take a look, front or back? Thanks, Anne
  • fowlerfamily Apr 30, 2009
    I just did this myself.  My Coupling was broken.
    Here's a video I found from this site.
    http://repair2000.com/coupling.html
  • Anonymous Mar 14, 2014
    motor runs, spin drains, agitator doesn't move
  • Anonymous Mar 22, 2014
    water is draining out from underneath the was while filling up
    President:
  • 878 Answers
Rick, for the posted model. This is a direct drive washer, no belt. As long as you are draining, I believe you have a broken motor coupler, about a 19.00 part. Check out the attachment, look at # 13. One end to the motor, the other to the trans. You will have to remove the cabinet, pump and motor to get at it. Easy job. Catriver.
Posted on Jun 17, 2007
  • Ron Marek
    Ron Marek Jun 17, 2007
    coupler
  • Ron Marek
    Motor coupler
The back panel is very simple to remove (10 screws) and provides wide open access to the belt. New belt costs $18 a service rep will charge you $50 plus plus $150 home service charge. Having both the Asko washer and drier for about six years, I have experienced multiple service repair bills that probably equal the value of buying new machines, so I now do the repairs myself, in fact I just removed the back panel on my washer about an hour ago to replace the washer motor (to the tune of $278). I'll stick with American made in the future or maybe that means Chinese made?
Posted on Jun 20, 2007
Why does my kitchenaid kaws750j washer fills w/water, aggitates and stops
it probably is over flowing which is triggering a kill switch
Sep 04, 2014 | Washing Machines
Whirlpool cabrio model 6300sw1 won't aggitate and gives ol code
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Download WHIRLPOOL CABRIO WTW6300SW1 Use Care Manual
Sep 03, 2014 | Whirlpool Washing Machines
My whirlpool Estate washer is not draining or spinning but aggitates, what can be the problem?
Sounds like a cycle switch problem. The switch is not turning and making contact with the next cycle. It needs to be changed!
Jan 09, 2013 | Whirlpool Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
I have a GE topload washer, I think the model # is WBSP1060T( there were three model # on the washer-VVSRV1040V & YVSR1040V were on there too) any way the water will not stop filling no matter what...
as to the filling issue this would either be the pressure switch or the hose that goes to the pressure switch to the tub has come off if you have any further questions message me back and please remember to rank this opinion it allows me to help others in similar situations Thanks Rick
p.s the starts agititating is normal when the lid closes it is engaging the lid switch
Mar 14, 2011 | GE WBSR3140D Top Load Washer
Will not aggitate or spin,
lid switch remove back panel switch on rt rear corner could have microswitch or fuse depends on mdl #
Feb 04, 2010 | Maytag Washing Machines
Series 70 washer will not aggitate, spin or drain
Even "empty" - there is still water in the tub to keep the seals moist.
Let it thaw completely - or put some hot water in the tub to thaw.
You may already have damaged the coupling/drive belt if it was frozen.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Kenmore 20722
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Water won't drain out
Possible lid lock, check the lid is locked when it should be spinning or pump jammed and check the draim filter. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
KitchenAid KAWS850LE Top Load Washer Logo
671 people viewed this question
Top KitchenAid Washing Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Sal De
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
