Question about Car Audio & Video
Jvc car audio KD-PDR51installation problem
Auto lead PC99-X44 and Patch lead PC99-JVC fitted on install Peugeot 307 2002reg. Radio stays after ignition switched off,Radio turns off via it's own switch.Also the steering wheel control does not work with the patch lead.Correct sequence of events on installation were done as instructed.
  • 15,935 Answers
Your switched ignition lead is hooked to a constant voltage wire.
You need to find a source wire that is only given power with the key in the on position.
One wire (yellow) on radio goes to a power wire with +12V constant power (regardless of key position)
The other wire (RED) on radio will need to be attached to a Power wire whose supply is only +12V when the ignition is enabled.
Since you are using a wire harness, you just need to reverse the 2 wires as they currently are installed.
Hope this solves one problem anyway.
the wires being reversed on the harness also may not activate an internal relay allowing the steering wheel functions to operate.Switch the 2 power wires, and re-try.
If the steering wheel controls still fail to operate properly, your module may be defective.
Post your results.
Posted on Jan 15, 2009
Hi I have a JVC KD-G801 car cd player/radio. Today a mechanic uninstalled it from a car I have which I will be selling and he installed into a newer Peugeot 306 I bought at the weekend. The stereo is...
Yes... the wire designated for constant power which powers the clock and some of the lessor memory functions is disconnected.
I would remove the radio and look for the lead that is disconnected and have a constant power lead attached to it to cure this issue.
Have the mechanic who did it the first time do it.. as it was already paid for him to do so in the first place...
Oct 06, 2010 | JVC KD-G801 CD Player
Installing in 2002 kia sedona and the harness is a different configuration .Are there adapters to allow usage.Thanks
Auto Zone, or a local car audio store should sell a stereo installation kit that will have the surround for the new stereo to mount in and fit where the stock radio was. It will also have a wiring harness adapter to plug into the stock radio connector.
May 25, 2010 | JVC KD-G140 Car CD Player
My jvc dosnt work in my astra
you need a pc99-x06 and then a patch lead which is stereo specific, so if you buy a JVC it will be pc99-jvc, alpine will be pc99-alp etc etc for your steering wheel controls (these are made by a company called autoleads who do loads of different stuff for car audio)
the stereo you purchase will have to be steering wheel control compatible, which should be stated in the description/instructions
you can have a sub amp etc with steering wheel controls, as thats run from the stereo and main wiring loom, and isn't affected by your steering wheel controls
Jul 26, 2009 | JVC KW-XG700 CD Player
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Changing car radios
Hi I disconnected the battery and but that on charge i removed the radio and checked all the wireing and i think what i may have found when the guy who installed it in the first place, when he was putting the radio in place with the wiring the jack plug to the remote stalk control had come detached.
thank you
denis
Jan 26, 2009 | JVC KD-G430 CD Player
Installing CD Player in Peugeot 206
Hi dont know if anyone reads this still. First the finger tip control you have to rewire it into the new cd player with a Autoleads PC99-X26 - Peugeot 206 plus connection to your make of radio. Also the wireing problem some times is down to the red and yellow wires being the wrong way round swap them over and this should solve this.
Oct 15, 2007 | JVC KD-G120 CD Player
Power will not stay on
Sounds like you're not getting voltage on the accessory power lead. This is the red wire at the back of the deck, and it supplies power whenever the key is switched on. It's possible that your vehicle's radio fuse is blown.
Aug 11, 2007 | JVC KD-PDR30 CD Player
Car Audio & Video Logo
271 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
