Question about Garmin Nuvi 680 GPS Receiver
Power cord doen not seem to recharge Garmin Nuve 680 in car.
Though there is battery charge as indicated on the devise - suddenly - when plugged into car - Garmin goes dead within a minute. Needs to be turned on again - and then goes dead again!
Works fine when plugged in at home or on battery alone - but not in car!!!
  • pamshaw13 Mar 10, 2009
    When plugged into car goes dead. When plugged in at home works fine.
To register my Garmin Nuvi. I want to get it registered, I tried before I'm not sure how far I got if it is registered or not
Posted on Jan 15, 2009
  • peaches3 Jan 15, 2009
    this is where I'm at I can't get back to the reistration
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
Garmin won't charge or turn on.
Hello :
How old is your battery ? I think that the battery life is ended [ can't be recharged anymore ] . Just replace it and problem will be solved .
please rate !
Apr 14, 2010 | Garmin nuvi 205 GPS Receiver
My Garmin 680 doesn't seem to hold a charge. How do I replace the battery?
Replacing the nuvi 680's battery is actually not all that hard as this video demonstrates:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+680&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi 680 is back up and running smoothly.
Jan 11, 2010 | Garmin Nuvi 680 GPS Receiver
I keep getting low battery message while my 750 is plugged in?
I'm still not 100% clear about why this is an issue (I'm having the same problem with my nüvi 760), but . . .
If you connect the Garmin to a power source via the USB port and leave it for a good long time (overnight) it should recharge even though the unit had been refusing to accept a charge through the normal power cord.
Jun 07, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Keeps powering down immediately after turning on
I have a similar issue, it does not even power on even connected to ac adapter.
May 22, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin 680 -cannot acquire satellites
If a factory reset does not work, your antenna will need to be replaced.
- Jim
Oct 28, 2008 | Garmin Nuvi 660 GPS Receiver
Palm Tungsten E2 won't work after power cord is removed.
The traditional steps for resetting charging problems are:
1) press reset /while/ the power cord is plugged in
2) unplugging the battery for about 30 seconds, then plugging it back in
You have done #2, but I do not know if you have done #1. Try it, then try to recharge again. If that fails then you probably need a new battery. I have found them on eBay before.
Feb 22, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Garmin Nuvi 680 GPS Receiver Logo
239 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
