Question about NorStar M7310 Corded Phone
I would like Line 6 on Norstar System to Ring Different
I have a Norstar phone with 6 incoming lines. The sixth line is for another company within our building which I must answer with a different company name. I "forget" to do this sometimes because all of the lines ring the same. Is there a way to program just that line so that it rings with a different tone?
  • Sherri Buford Jan 16, 2009
    That just changes the ring for the phone, I need it for one specific line. Thanks for trying!
  • Anonymous Mar 26, 2014
    norstar 7324 phone line 3 will ring back on hang up and has a stutter tone
I also have 6 incoming lines and would like one line to ring different same senerio as above. Were you ever able to do this? and if so how?
Posted on May 25, 2012
  • 326 Answers
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Posted on Jan 16, 2009
  • 1 more comment
  • mark hudson Jan 16, 2009
    sorry, not sure if you can set the line to a different ring tone, if you set the other phone to a different ring type isnt that your problem solved?
    very sorry, just read that again. ive read it as you have 6 phones. let me see what i can find
    scroll down to the ringing sounds 1,2,3,4 near the bottom, dont think it can be done
Remove the ringing from incoming calls on a norstar. I have multiple extensions in the building but want the incoming calls only to ring to a few extensions
You need administrative rights to get into the PBX. Once in there, you can assign which phones receive incoming calls. It has been years since I worked on the meridian system, so I can't tell you the way to do it, but it is in the manual. It's not complicated. You can also set it up for DAY/NIGHT mode so that in the evening, if required, all phones could ring on incoming calls so that anyone in the building can answer them.
Feb 04, 2015 | NorStar Meridian M7310 Phone
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
Sep 25, 2014 | NorStar T7316E Telephone
One of my incoming calls gets a fax tone. i answer calls for a bunch of different companies and it is just this one line that does it.
1. The line may be wired to a security system or fax. or
2. The IRAD (internal remote answer device) on the system may be answering that line.
Sep 05, 2014 | NorStar M7324 Telephone
How to make phone ring for two incoming lines
This is tech side programming known as Configuration, clients usually call in a tech/vendor for this.
You need to find out the password and know how to navigate the system programming, do F**266344 and enter the password.
Navigate to Sets, add line in question , assign ring type.
Dec 10, 2012 | Nortel Lands Phones
The phone in my office shows the 9 lines available for incoming calls, but will only ring when a call is being transferred to my line. I occasionally cover all the lines for our dispatch and need to be...
You will need to contact whoever is in charge of your phone system and have them setup what is called a hunt group. This would be managed by IT in large businesses and usually the local phone company for small businesses.
May 05, 2011 | NorStar M7310 Corded Phone
Would like different ringtone for 6th line.
Hello. Call the company that provides your phone and ask to speak with a technician.
? # 1 - is this phone capable of doing what I want to do as it is now configured?
If yes, please talk me through it.
If no, what will it take for this function to be added.
Aug 19, 2009 | NorStar M7310 Corded Phone
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Incoming calls ring on intercom rather than appropriate line.
Somehow you might have taken the lines off the extension. I would double check that under line appearance, that extension is set to "appear and ring" for each line.
Dec 08, 2008 | NorStar M7310 Corded Phone
No ring and appear on my Norstar M7310
This should work on M7310, M7324 & T7316
Feature ** 266344 - password 266344 - configuration - line data - line access - show ext (yours) - line assignment ( which lines you have, usually 1 & 2) - show line - appear only/ring/apprear and ring
Hope this helps
Oct 02, 2008 | NorStar Meridian M7310 Phone
Only First Phone in the system will ring on incoming calls
These manuals are available on the norstar web site.
Jul 08, 2008 | NorStar M7310 Corded Phone
NorStar M7310 Corded Phone Logo
698 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
