Question about Toro Lawn Mower With Toro Power Tools
Will not throw snow
I have a toro cc3650 that dosn't want to throw snow, I changed the blet and still nothing?
  • toro4211991 Jan 15, 2009
    I have 421 toro snowblower won't started after the shop ..had struggled to starter and how to operater to starter??
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Posted on Jan 15, 2009
Have a toro 2450 5 hp snowblower used to throw snow at least 8ft now lucky to go 1ft changed belt last year thought that was problem but didn't fix the problem any suggestions? Thank you
Just a thought. Is the belt tight or does it slip when you put pressure on it. Check and see if the impeller outfit is plugged. Mine did that and it was plugged with an old shirt I picked up in the snow. Can you turn the impeller by hand when the engine is shut down. If so could be a shear pin broke off in the impeller.
Dec 30, 2017 | Toro Garden
I have a Toro Power max 1323, auger turns but does not throw snow
only a guess of course but if this a 2 stage then you missed a shearboth to the blower if auger runs and it doesn't throw it out
Feb 02, 2015 | Garden
Engine surging Toro 621 38452 unless on half choke
you have dirt in your carb blocking fuel to engine. clean carb
Apr 09, 2014 | Toro 38452 - Power Clear 621E Electric...
Toro ccr3600
it sounds like it is not running high enough has to run pretty high on the rpm so it can throw it out the chute unless your rubber or steel blades are worn
Jan 05, 2014 | Toro Garden
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
The engine starts but won't actually throw snow the wheel that turns to throw snow is not turning
There is probably a shear pin or bolt that has broken, providing all other belts and accessories are intact. Should be very simple to take the bolt out of the wheel where it attaches to the shaft. Just take it to a hardware store or an outdoor store that sells snowblowers.
Feb 17, 2010 | Toro Lawn Mower With Toro Power Tools
Toro S200 doesn't blow to the side as far as it did
It's possible your auger may be worn, and it is not moving / propelling enough snow to make up the difference to blow the snow at the angled setting. It may throw the snow forward better due to less resistance, rather than the snow having to propel around an angle / curve. Just a thought for now.
Jan 20, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Huskee Snowblower has to be constantly at high RPM to throw snow
It sounds like the sping that goes from the throttle lever to the govonor arm is either streched or broken.
Jan 20, 2009 | Toro Blowers Rake and Vac - Electric...
Toro Lawn Mower With Toro Power Tools Logo
731 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
