Question about GE JVM1630 Microwave Oven
Ge XL spacesaver Microwave blowing fuses
When I replace fuse the unit will work for about a week, then the fuse will blow again, this keeps repeating
There doesn't appear to be a reason. I go to use it in the morning and its dead yet it worked the last time it was tried.
Any idea what can cause this behaviour?
    Problem Solver:
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Posted on Jan 15, 2009
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
GE JES1855 1100 Watts Microwave Oven not working. Display lights do not come on. Checked wall plug and it is ok.
Sounds like internal fault protection fuse blew. can be fixed by qualified technicians. their is very high voltage coils and capacitors within this unit and can cause harm or death instantly if not discharged properly.
Aug 12, 2010 | GE JES1855 Microwave Oven
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
Fuse blows after about a week of working.
if you have a fuse that keeps blowing you have a short somewhere May or may not be cheaper to buy a new one
Sep 07, 2009 | Jenn-Air JMC7000 Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Where do I find the fuse?
yes you do and this is not reall advisable as there is high voltage components inside.thre is normally a fault with the machine if it blows a fuse.if you want to still try then make sure yoiu unplug it and short the plug on some metal to get rid of any stored charge.the main things to blow a fuse is the door switches sticking,the bulb blowing or a fault with the high voltage system which you would need a special multimeter to yest,hope this helps
Jul 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Fuse keeps blowing
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave XL 1800
remove top cover of oven , check fuse and control unit, high voltage section and diodes and capacitor and magnetron,
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630 Microwave Oven Logo
192 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
