Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
Incapatiblity input signal when turning on Sharp Aquos LC-46D43U
Sharp Aquos LC-46D43U displays an incapatible signal message when initially being turned on. HDMI from Harman Kardon AVR745 utilizes high quality (price) Monter cable. TV will eventually respond after cycling it off and on several (up to 10) times. Very frustrating, especially when I'm not home and the family wants to watch programming. TV has just past its warranty period (of coarse) and money is tight. Any information on resolving this issue would be great...
  • chuckehin Jan 15, 2009
    If thats the case, why would the signal be eventually picked up after cycling the TV on and off only. It would seem to me, that if my other devices (HDDVR and Harman ****** reciever) remaind on while the TV was cycled, that the issue would ly in the TV. Any other suggestions would be helpful...Thanks...
    Sergeant:
  • 378 Answers
As per my knowledge its a receivers problem.but at the same time also check the cable connections to cofirm that the receiver is creating this problem.
Posted on Jan 15, 2009
  • 10,594 Answers
Please make sure that Input-4 or Input-5 which is being used (HDMI Inputs) are not skipped in Menu.
Please enable 'Auto View' for HDMI Inputs by going in to HDMI Setup Menu in TV.
  • Sharp Master
  • 19,396 Answers
The problem is either the receiver, the HDMI cable / connection, or the TV itself.
The receiver/computer/dvd:
Test if connecting TV to a different device by HDMI you still have a problem. If you do not have the problem, the device sending the signal does not work well with this TV, it may happen.
The cable:
Many HDMI cables can give you this kind of troubles, try replacing the cable with a good quality one.
The TV, an internal fault, or a problem with the signal board (I/O board) on TV can be the cause, but that is rather unlikely.
    Top Expert:
  • Sharp Master
  • 77,202 Answers
As u may have guessed the signal from the HDMI cable is a digital coded signal that must be locked on to by the TV's decoder before the information becomes availiable, the problem may not be with the TV but the player, without another DVD player it is hard to say which one is at fault,
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
Sharp LC-46d43u won't power up
Check and replace its main power supply regulator board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
What is the TV Tuner Signal Board part number for the Sharp Aquos LC-52d64U?
That the board which it have a square aluminun box at the edge of the board with a rounded bolt sticking out for inputs like ANT. input and AV inputs for like wires components inputs like multi colors like YRW,YRWGP holes for AV inputs also have HDMI hubs inputs for the high Def Pic.There are 6 HDMI inputs hubs for the tv Sharp Aquos LC-52d64U.Tvs Tuner board signal boards are also have to been known names to called as the tvs Main Logic boards and the tvs Mother boards also.U are fixing ur tv u must have to take it parts already.U can also compare the pictures between the tv Tuner signal board u are taking aparts out of the tv and the tv Tuner signal board you are buying they'll look axactly alike.The sticker of the serial numbers of the boards a few numbers in the begining on the tv Tuner signal boards should be the same also.
Dec 06, 2011 | Televison & Video
How do I get my Sharp Aquos LC-32D43U to work as the monitor for my laptop computer. On key potential issue seems to be that the operating manual suggests pressing the "menu" button, followed by "setup"...
Not sure why u need to go to menu. If you want to connect lapotop to TV attach the cable turn on laptop and monitor and hit FN F5 the laptop screen will then be diusplayed on monitor Fn F9 turns it off
please4rate my help++++Thanks for using FIXYA
May 08, 2010 | Sharp AQUOS LC-32D43U 32 in. LCD...
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Lc-46d43u aquos lcd tv
The remote code 31 worked on my Motorola cable box.
The REmote is for a Sharp LC-32GP1U
The code was listed under one of many for Jerold. I entered codes one by one testing the secondary power button each time.
Code 31 works fine.
Oct 28, 2008 | Sharp LC-26D6U 26 in. LCD Television
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
No Video on Sharp Aquos LC-46D62U
Have you check all inputs as the HDMI inputs and the composit inputs are processed on a different bd?
Feb 26, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
