Question about Toshiba DKT2010SD Phone
Need to change the speed dial
Or need acess to the manual
  • 45 Answers
YOU CAN GO TO
WWW.AMERITELNJ.COM
TONY
Posted on Apr 07, 2009
How to change the shutter speed on my nikon n65 film 35mm slr camera
In the manual and shutter-priority modes (set the dial to "M" or "S"), turn the command dial to change the shutter speed. In the aperture-priority mode (set the dial to "A"), turning the command dial changes the aperture and the camera will set the shutter speed appropriately.
If you need a manual, you may download a copy from here.
Oct 13, 2012 | Nikon N65 35mm SLR Camera
How do you set the aperture and shutter speed independently
First, make sure you're in the manual exposure mode, not manual focus mode, as set by turning the mode dial to the "M" position.
In manual exposure mode, turning the main command dial should change the aperture, while turning the subcommand dial should change the shutter speed.
If the two command dials don't have the expected effect, reply to this post and we can troubleshoot further.
Feb 20, 2012 | Olympus E-1 Digital Camera
How do i change my aperture setting on my samsung v800?
Turn the mode dial to "A". Turn the jog dial to change the aperture and the camera will change the shutter speed to match. You can also go to the manual mode, where you have to set both the aperture and shutter speed.
Full details are in the "How to use the APERTURE PRIORITY mode" section of the manual (page 22 in my copy). If you need a copy of the manual, you may download one here.
Aug 24, 2010 | Samsung Digimax V800 Digital Camera
I need to recall the system speed dial directory on my NEC Electra telephone system. I am unable to find a memory re-call/display feature in my manual.
With this old model of phone you don't have the soft keys to scroll through the directory like the newer models have.
In order to check the system speed dials you will need to check them manually:
System Speed Dial #'s
LNR/SPD key and the system speed # 00~79
Station Speed Dial #'s
LNR/SPD key and the system speed # 80~99
This will dial the # and/or display the name associated with the speed dial.
In order to program them refer to this manual:
Elite IPK Features and Specs
Look under Speed dial-Station or System.
Nov 11, 2009 | NEC Electra Professional ETW-16DC-2
Group speed dial option is not lit up and will not let me click on it.....
http://www.brother-usa.com/Manuals/Default.aspx?WT.cg_n=Support&WT.cg_s=Manuals
Pages 5-1 thru 5-3 in the Users Guide cover One Touch, Speed Dial and Group Dialing (Broadcast Dialing). Apparently one touch and/or speed dialing need to be set up first. Hope this helps.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
I can't change the speed dial numbers on my phone
You should only have to hit Feature - Redial and then select the soft key that you wish to re-program. Typically you will then type 1 and then the extension you want to program.
Jul 06, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Setting the date
By programming, these are programs 000,001 and 002 for Date and Time, Speed Dial number, and Speed Dial Name.
Date and time programming is easy, I don't wish manual speed dial entry on my worst enemy. However, if you like a challenge, I'm going to give you a link to the programming manual.
http://public.carl.airpost.net/TDA/TDA_PTPM_32.pdf
Start with page 12, since you'll need it to get into programming.
Your key sequences begin on page 16. After you put the first 5 or 10 speed dial numbers and names in, you'll get the hang of entering names in the directory. Nothing changes until you press ENTER or STORE. Each speed dial number starts with a trunk access code (usually 9) as part of the number. In name entry, each time you press the key it changes a letter. In a TDA IIRC 7 presses of the 2 key will get you ABCabc2.
Carl
Mar 19, 2009 | Panasonic KX-T7630 Corded Phone
I want to change speed dial nos. don't have manual for instructio
You should be able to download the appropriate manual from
http://uniden.com/index/manuals_results.cfm
Jan 07, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Toshiba DKT2010SD Phone Logo
184 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
