Question about Keyspan (USA-19QW) Serial Adapter
Built wire OBDII to usb
How can i construct this wire? From OBDII port to usb?
  • gsk Jan 15, 2009
    I want from OBD to USB. Not to 9pin.
  • 15,935 Answers
HERE it is... or save yourself time and hassle, and BUY one.
Posted on Jan 15, 2009
1999 mitsubishi eclipse spyder gs
Could be the fuse for the cig lighter, or a problem with the computer.
Jun 25, 2013 | Cars & Trucks
Tip
PS3 models, and what they can do
The 20 Gig
Pros
Full PS2 Compatibility
HDMI Port
Pretty good Cooling System
4 USB Ports
£220
Cons
Super Small HDD
No Wireless Card
Discontinued (They don't make them any more)
The 40 Gig
Pros
£250
HDMI Port
Built in Wireless
Medium HDD
Amazing, New Cooling System
Cons
2 USB Ports
Cannot play PS2 Games
The 60 Gig
Pros
SD Card Slots
4 USB Ports
Built In Wireless
Big HDD
HDMI Port
£280
Cons
The *OLD* 80 Gig
Pros
Massive HDD
4 USB Ports
Limited PS2 Compatibility
SD Card Slots
HDMI Port
£280
Cons
The *NEW* 80 Gig
Pros
Massive HDD
£250
HDMI Port
Built in Wireless
Cons
NO PS2 Compatibility
The 160 Gig
Pros
Mammoth HDD
HDMI Port
Built in Wireless
Cons
£350
on Jan 18, 2010 | Video Game Consoles & Games
After connecting the flash drive into usb port. whats the next thing to click to download
insert flash drive into USB port...click on my computer and it'll show you the drives that are running and the flash drive you have plugged in right click to open drop down click open to access contents.. hope it helps :-)
Feb 07, 2012 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
I have a Logitech Z-5 Speakers which connect to my laptop by usb. the light doesn't come on on the speaker.. looks like the usb wire isn't working or a fuse has blown due to a power outage. what do you...
Did you try using a different USB port.
If there is any short of the cable then on PC there should be a massage like "Power Surge of USB port", if you don't receive this massage then probably something wrong inside the speaker.
Mar 12, 2011 | Computers & Internet
Checking/changing sensors on 2004 toyota camry is a big job? What connection does it have with the computer?
Google OBDII or OBD2 is your first step.
OBDII scanner start at $50+
All 1996+ vehicle has OBD connector within 18" from the center of the dashboard.
It's a worthwhile investment on a better scanner that can do OBDII and CAN bus. The price is over $80+
If you are into automotive in the long ran then you should get OBDII and CAN bus scanner.
Some high end scanner can download collected error code and link it to a PC via USB or serial port.
This will allow you to look up the database for potential fix.
Jul 08, 2010 | 2004 Toyota Camry
Need steps to reprogram chevy suburban 1997 keyless entery
1. Locate the Data Link Port. It is located under dash drivers side. Be sure you know
which pins are 8 and 4.
(Note port is wider at top) Your OBDII port will not
have numbers, use the for reference.
2. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 to 4 with a
suitable jumper wire (leave the jumper wire connected throughout the programming
procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond
by locking and unlocking the
doors to signify entering of programming mode.
3. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to
be programmed. After about 15 seconds, the vehicle will respond by locking and
unlocking the doors. Release the buttons on the transmitter.
4. Within one minute, repeat the previous step on the remaining transmitters to be
programmed.
5. Remove jumper wire applied to the OBDII Port.
Jan 15, 2009 | 1997 Chevrolet Suburban
I set my router up as a network and all I want it to do is run a laptop. How do I get it to do just that?
Did you have it working with another computer before? It would normally use an ethernet cable between the router and laptop.
Your laptop needs an ethernet connector (or maybe a USB port if your router supports a USB connector). Sometimes the ethernet port is built into the laptop. It looks like a phone jack (you may have a couple of modem jacks on your laptop, which is not what you want). It's bigger and has 6 wires instead of 4. Another way to connect an ethernet cable to your laptop is a PCMCIA card. They plug into a thin, wide port on the side of your laptop. It also would have the 6-wire jack built into it. Router setup is another issue if you need help with that.
Dec 02, 2008 | Computers & Internet
Keyless remote programming
1. Insert keys in ignition and leave in the OFF position.
2. Locate the OBDII Port under drivers side dashboard.
(Note port is wider at top) Your OBDII Port will not have numbers, use this for reference.
3. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 and 4 with a suitable
jumper wire (leave the jumper wire connected throughout the programming procedure). Make
sure you know which terminals are 8 and 4. The vehicle will respond by locking then unlocking the
4. Close Doors
5.
Turn ignition to the ON position (as far as you can go without cranking the engine).
Doors will
lock.
6. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be
programmed. Up to about 30 seconds, the vehicle will respond by locking then unlocking the doors.
7. Within one minute, repeat the previous step on the remaining transmitter (if any – including any
existing remotes).
8. Remove jumper wire applied to the OBDII Port
Nov 25, 2008 | 1998 Buick Riviera
Keyspan (USA-19QW) Serial Adapter Logo
527 people viewed this question
Top Keyspan Computers & Internet Experts
David Payne
David Payne
Are you a Keyspan Computer and Internet Expert? Answer questions, earn points and help others
