Question about Dell 1600n All-In-One Laser Printer
Dell fax machine will not recognize incoming fax call on comcast cable telephone line
  • Anonymous Mar 05, 2009
    i can ot receive fax
  • 15,935 Answers
Direct from COMCAST FAQ:
Do fax machines work with Comcast Digital Voice service? Yes. However, there may be some equipment brands or models that are incompatible with Comcast Digital Voice® service. Click here to review a list of equipment that has been known to have compatibility issues with Comcast Digital Voice service.
Posted on Jan 15, 2009
My fax machine is saying off hook but the printer is working
Hello, my name is Steve. It sounds like your Fax machine has detected that the phone lie to your machine is still "opened".
The Fax board that detects the signal for the incoming fax tone is either not connected or it has an open circuit.
If you have another cable that goes to the Fax try this as a replacement. If this corrects the problem, then the fault is the cable from the connection of the wall to the fax machine.
If this does not, then if you have another source, connect a telephone. If you hear a dial-tone then it is not the line-in.
The part that failed is the Fax-card or the Logic board...
I hope this helps, best regards,steve
Aug 18, 2015 | Canon Pixma Mx459 All-in-one Inkjet...
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
All of my test fax are no answer. I have the
Your cable modem is not normally a source for telephone line that the fax machine will support. If you have telephone service through Comcast, You need to contact them about proper hookup to configure your fax line.
Apr 12, 2010 | HP Officejet 6310 All-In-One InkJet...
Dell printer A940 fax trouble
Unless you have 'VOIP' telephone service with Comcast, your FAX will connect through your home's telephone line, not the internet (or modem). You would connect your phone line to the all-in-one printer, then follow Dell's instructions for use. Good luck!
Apr 18, 2009 | Dell A940 All-In-One InkJet Printer
Cable telephone lines are DIGITAL, fax machines are ANALOG devices. It will not work reliably on the ComCast line.
Dec 19, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
I have changed from a 2 line phone system to a 1 line. I am still using the same 2 line wireless telephone/answering machine. The telephone will only work for outgoing calls and not for incoming. The HP...
I just bought a used hp 3200se and am trying to use it as a stand alone fax. It (so far) does not answer incoming calls. I found that I can manually answer a fax call and then the machine seems to work fine.
I tried connecting to ...oh, by the way, I have digital phone service from Comcast, an analog line and it seems to work fine. So maybe the 6310xi is the same or maybe there are setting to deal with a digital line. Maybe something in this will help.
John Mavis
Nov 03, 2008 | HP Office Equipment & Supplies
Brother Intellifax 770 fax machine failure to receive faxes
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Receiving a fax
Faxes fail intermittently or with only one fax number
  • If static is present on the phone line, fax communication may fail. Have the phone line checked and serviced by the telephone company (or have the other party check their line). Phone line quality is the most common reason for intermittent fax failures. Some older locations and buildings have inadequate phone system wiring.
  • If you are trying to send a color fax and it fails, try sending the same machine a black and white fax. Normally the fax will detect that the other fax is not color capable and will offer you the option to send the fax as black and white but this might not always be the case. Do not send color faxes unless you know the other fax machine is capable of receiving color faxes.
  • Check the phone cable from the wall jack to the fax. It should not be coiled or longer than necessary. Coiling the cable can cause cross talk or echo on the line. Signal strength and quality can be lost with long cables.
  • Make sure the phone cable routing (and any cables not plugged into the same jack but sharing the same line) is not near any electrical appliances (electric motors, fans, kitchen appliances, or televisions). Many of these devices do not have sufficient electrical shielding and can induce electro-magnetic force (EMF) onto the phone line. Computers are usually shielded sufficiently and do not cause this problem.
  • Do not use a call-waiting service on the same line connected to the fax machine. The click sound caused by an incoming call can cause the fax to fail.
  • You can block certain faxes on some models. Verify that the telephone number of the sending fax is not blocked in the faxing software. This is usually located in the Fax History.
Nov 08, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Receiving incoming faxes
# Press the button to enter Fax mode. # Press . # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Aug 07, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Dell 1600n All-In-One Laser Printer Logo
253 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
