Question about Toshiba DKT2010SD Phone
I do not have the manual for Toshiba DKT2010-SD and i need to change the speed dial as well as get the phone to ring again. Or i just need a copy of the Manual.
    President:
  • 623 Answers
You can find the manual on Toshiba's web site (here).
Posted on Jan 15, 2009
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
Please download me instructions on how to change time in our Toshiba Phones at work with Model No. DKT2010-SD. Also I am requesting a Manual for the Toshiba DKT2010-SD phone system. Your tech support...
Changing the time on a Strata DK system must be done from the "main" or primary phone. It is usually extension # 10, or # 200. 1.- With the phone on-hook, dial intercom, #, 652 (depending on the system type, the # may or may not apply) 2.- Enter the correct time using HH/MM/SS, like 07:24:00 3.- Press redial As far as the system manual goes, I'll need to know the type of system you have. Toshiba DKT2010's work with a number fo different Toshiba systems. To find out, go to where the phone system is located and look at the top corner. It should have a number designation there such as DK 40i or DK280 etc.
Nov 08, 2010 | Toshiba DKT2010SD Phone
I have Toshiba dkt2010-sd telephones and need to update our speed dial directory, but the person who did this left. How do I reprogram the numbers?
it depend on the system, but usually on the main phone Ext:10 or 200 press redial then speed dial then "BIN" number ( 10-49 for user 60-99 on system dials or 600-699 for large system dials) then type the number with 9 in front if you dial that to dial out .. finish by pressing redial.
Dec 22, 2009 | Toshiba DKT-2010 Corded Phone
How do you change the number of rings before the voicemail will pick up on a toshiba dkt2010-sd
Do you have a display phone? does it say something like CF/NA to XXX in the top? If it does press Intercom #603 then the XXX from above press Speed Dial then the number of seconds to wait usually 24 then press redial. If it does not have that displayed it is adjusted through voice mail programming. the admin program and guides for your phone can be found here
http://guides.idacomusa.com/
Jul 28, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-sd ringing in ear while on a call
1) To stop the ringing in your ear, press Redial and Vol Down at the same time
The following must be performed from station 10 or 200.
2) To change date : Press INTCM, #, 6, 5, 1, Enter date YY/MM/DD, press redial
3) To change time : Press INTCM, #, 6, 5, 2, Enter time HH/MM/SS in 24 Hr Format, press redial
4) To change day of week : Press INTCM, #, 6, 5, 3, Enter day (1=Sun, 2=Mon...), press redial
For more information regarding your Toshiba DKT 2010 Phone and the system that you're using, feel free to browse our extensive guides and manuals that you can find here
Or you can call me at 1-800-903-9190
May 05, 2009 | Toshiba DKT2010SD Phone
How do I set up and use speed dial on a Toshiba dkt2010-sd
what system u using??
if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
- to set speed dial press REDIAL SPEED DIAL standard speed dial   code 60 or 600, follow by 9+destination number, REDIAL to confirm.
- to call press speed dial + code or press * + speed dial code (*60 / *600)
- if CTX/CIX must set at adminsrater phone. #66, speed dial code number (200-999), 9 follow destination number #
- to dial press *200...
Apr 22, 2009 | Toshiba DKT2020SD Phone
How do I set up speed dial for a Toshiba DKT2010-Sd phone
what system u using??if DK series go to phone port number "000" (at phone press Intercom #401 to check port), check at every phone with display phone.
Toshiba DKT2010-SD won't ring
ask the provider to program the ringging assignment. It wont ring couse dint assign a ringging assignment.
Feb 13, 2009 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
Changing Voice Mail Password from the TOSHIBA DKT2010-SD set
you will need to download the manuall you should be able to get it off this sight hope this is some help
Oct 30, 2007 | Toshiba DKT-2010 Corded Phone
Toshiba DKT2010SD Phone Logo
833 people viewed this question
Top Toshiba Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
