Question about GE JEM31 Microwave Oven
Burned inside of microwave
I have a GE microwave, JEM 31, about 5 years old. I put a plastic bottle of maple syrup into it (removed the cap) to heat up, but it caught fire as did the inside plastic roof of the microwave. Now the plastic inside comes down like an upside-down volcano, burned. Can I still use the microwave? Can I replace the burned part?
I'd prefer not to get a new one because it is inset into a cabinet made just for its small size and I don't think the new models would fit.
  • GE Master
  • 9,098 Answers
This is the the stirrer cover, and it provides important protection for the magnetron and must be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 18, 2009
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
JEM 31 is not heating
Sounds like you have a bad transformer. Magnatron should check less than 1 ohm (with wires unplugged). Diode should check resistance one way and open the other. Must have a proper diode checker for this. Check resistance on the capacitor (make sure it is discharged first). Resistance should come up then back to open, reverse and same thing if cap. is good. Check resistance on transformer windings.
Nov 05, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker and it is about 9 yrs. old. Sometines it heats; other times it doesn't. I change settings and sometimes that works. Is this something that can be repaired or is this a sign I need...
When the microwave is not heating, that means the magnetron is not working. This is what provides the heat to the microwave. I do believe the magnetron has a 10 year warranty.
If you wish to replace it, here is how:
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Sep 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove the rack holder from a GE JMV1340WW002 microwave.
Hi best way is to remove the outer case and cut the back of the clip off, alternativly you can just lift the old clip from inside the oven cooking cavity with a flat knife or spreader untill the plastic clip on the rearside breaks off, it'l just fall down and sit in a void in the bottom of the oven and wont cause any damage. The new clip is just installed using an upward motion whilst pushing inward untill it clicks into place.
Hope this helps
Jan 07, 2010 | Microwave Ovens
GE Profie JE1860SH 04 microwave sparks
Our JE1860SH was also sparking after a few seconds. The GE tech pulled the upper round disk and found the problem. The plastic was burned and the round metal which is behind the plastic dome was arching with the frame. Lasted seven years expected more especially from a GE product. So my suggestion is to remove the dome and check it out.
Jan 03, 2010 | GE Profile Spacemaker Over-the-Range...
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replace burned inside ceiling of microwave?
Do Not Use The Microwave. If You Need Parts Try Finding A Part Number And Use Ge To Order Parts. Click Here To Order Parts
Jan 15, 2009 | GE JEM31 Microwave Oven
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge over the range microwave
well randy you might want to check the diode and cap with a meter first before getting the mag tube. if both of those parts are fine. replace the tube.
Apr 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Apr 10, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE JEM31 Microwave Oven Logo
162 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
