Computers & Internet Logo
Kim Sullivan Posted on Dec 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a manual so I can set up my cyberpower gamer ultra gua 250 desktop computer
Computer didn't come with set up manual or instructions....where the wires go etc..... don't know if I need to run disks that were sent with it or not.... (gigabyte amd 9/8/7-series utility dvd) have no instructions whatsoever ! I am a mother trying to set up her sons gaming computer (computer illiterate) ...and it would be nice to know how to set it up ! :)
max carson
Level 3:
  • Master 7,627 Answers
  • Posted on Dec 21, 2012
max carson
Master
Level 3:
Answers
7627
Questions
Helped
1013714
Points
21773
You can start here the video to the right may be better quality: http://www.youtube.com/watch?v=pbagHAzRwJc OR try Here for support/manuals: http://www.cyberpowerpc.com/support/
5 Related Answers
Anonymous
  • 1226 Answers
  • Posted on Oct 20, 2008
SOURCE: remove raid to allow installation of sata
REset your Bios setting ..and then boot your computer to safe mode and then remove the raid installation from the add/remove programs....do not boot your computer from the utility disk.
melnavz
Anonymous
  • 749 Answers
  • Posted on Oct 21, 2008
SOURCE: I need help! I'm
here is what you will need to complete this project:
  • Your new DVD burner with the included screws and cable.
  • A phillips screwdriver.
  • your new harddrive
  • Once you unpack the drive and find a screwdriver, you can finish the prep work by turning off and unplugging the power from your PC.
Installing Your Harddrive Step1 Open up your case after backing up any important files and locating and installing any software that came with the hard drive. Check to make sure that your computer supports SATA or that you have a SATA PCI card installed. Step2Look for the smaller connector on the SATA cable and connect it to the SATA connector located on the motherboard or controller card. If you already have another SATA drive, simply follow its cable to the motherboard or card to see where this one will attach. Step3Grab the larger end of the SATA cable and connect it to the back of the SATA drive itself. You will also need to attach the legacy 4-pin connector or SATA power cable to power your drive. At this point, check to see that both the smaller and larger end of the SATA cable and the power cable are securely connected and proceed. Step4Choose an available drive bay and insert the hard drive into it, mounting it in place with the four screws provided. Make sure to follow the directions that came with your drive and place the screws in the designated holes to secure proper grounding. Step5Ensure that all cables are properly attached and replace the tower or desktop case cover. After doing this, you're all set to reconnect the power cord and turn on your computer. Formatting and Partitioning Step1Boot from your Windows CD. If this is the only hard drive present, you'll be shown a series of instructions and should simply follow along. Step2Select "Control Panel" then "Performance and Maintenance" and finally "Administrative Tools" for an additional hard drive. Then click the "Computer Management option and choose "Disk Management." Simply right-click the drive to partition and format it. Step3Follow the steps displayed. Windows will guide you through the rest of the process. Now for your dvd drive---- 1.Shut down the system, unplug the power cord and remove the side panel or panels from the case. Ensure that the new DVD-ROM drive is set to be "Slave" or "Master," depending on if it is a replacement or an additional drive. 3 2.Locate the empty drive bay for the new DVD-ROM drive, and remove the drive bay covering. 4 Insert the new DVD-ROM drive into the empty bay and secure with screws or other attaching device provided by the manufacturer. 5 3.Connect the open connector on the ribbon cable (red stripe towards power cable) to the new DVD-ROM drive and connect the power supply cable (plastic four connector plug from power supply)to the drive. 6 Replace the side panel or panels, plug in the power cord and turn the system on. Install your dvd software bundle and get to work. These are actually two things you will want to do at once while the computer is open , but i would do them one at a time in case you have problems you will know what to blame. You can leave the cover off while operating the computer so that you can test it after the hard drive instrall and before the dvd install.
A
Anonymous
  • Posted on Nov 03, 2008
SOURCE: PCV-W20 Partition sizes
Hi,MY SONY VAIO PCV-W20 PERSONAL COMPUTER HARD DISK GOT CRASHED,I GOT NEW HARD DRIVE I DONT HAVE DRIVERS AND I TRIED ALL THE WAY SEARCHING DRIVERS ON THE INTERNET EVEN IT IS NOT AVAILABLE ON SONY VAIO SITE, PLEASE GIVE ME SOLUTION, THANKS YM
Anonymous
  • 157 Answers
  • Posted on Mar 04, 2009
SOURCE: I have a CyberPower Gamer Ultra 6230 Desktop PC
Windows systems are notorious for crashing for any number of reasons and in a number of ways. Some of these crashes are mild and can easily be overcome simply by closing a nonresponding application or by rebooting the system. However, others are more serious and can bring the entire system to its knees. Microsoft calls these types of crashes "Stop errors" because the operating system stops responding. When a Stop error occurs, the GUI is replaced by a DOS-like blue screen with a cryptic error message followed by a code number. This screen is affectionately referred to as the Blue Screen Of Death.
what i mean, try to reformat in zero level of your HDD and install OS...
Anonymous
  • 135 Answers
  • Posted on Mar 14, 2009
SOURCE: eMachine T2482 Computer won't power on or boot up.
Check the power connection physically make sure that it is connected properly, try other power outlets, if still nothing happen? the problem is on the power supply of the computer, you might replace it. it think there's no switch on the mother board.
1helpful
Saying memory full and wont load to home screen
Tty doing a "Hard Boot". Disconnect the power. Hold the power button in for about 3 seconds. Reconnect the power cord and try to turn it on. If that doesn't work you might have a virus or a hard drive problem.
How do I hookup my side panel blue LED fan?
There is usually a fan connector on the motherboard. Do you have a manual for the motherboard? Check around the center of the motherboard for a label such as "case fan". If this computer came as a full package, why isn't the fan already connected? Did you add it afterwards?
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
How do I restore the BIOS settings on my Cyberpower Windows 8 64-Bit Gamer Ultra 2150. I installed a new graphics card and went into my BIOS to change the setting and after I saved new settings I have no...
You should remove the CMOS battery from motherboard for 10-15 second and than put it again. When you change the graphic card, you shouldn't go to BIOS, just install the Driver for your new grapic card. bed355b8-0e7a-4736-bf41-c4eb95ebe7a5.jpg
I cant find the sd card port
Specs don't show a slot, which is normal for desktops. You may have to use an adapter via USB.
http://reviews.cnet.com/desktops/cyberpower-gamer-infinity-sli/4507-3118_7-33342066.html
2answers
My Cyberpower computer has a wireless adapter thing on it, but I can't seem to connect to my wireless internet connection downstairs. It keeps sayig that I have to turn on a wireless switch. Could you...
sometime the wireless cards have a setting within it that allows the card to turn itself on and off to save power. i would check the setting within the properties and see if any energy saving setting are set. if that doesnt work contact the make of this pc. it looks like a custom pc build and i know some companies built and sell these pc.
I bought my son a Cyberpower i107 computer. He got it today and it will not power up. What should we do?
First check to make sure the power switch on the back of the power supply is switched to on (it's next to where the power cord plugs into the computer). If it is switched to on (the 1 symbol down) and it still isn't working, try a different outlet. If that doesn't work then you will have to look into returning it, the sooner the better.
My account in crossfire
email the admin and have them do an investigation ... please rate me/..
1helpful
Need help finding compatible SLI video card
Just buy another NVIDIA GeForce GTS250 512MB PCI Express Video Card, same as the one already in it. Two exactly the same cards always work in SLI. If you need any more help, let me know. Regards, Yannick.
Top CyberPower Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
