Question about HP 10bII Calculator
STuck on screen
says -4. 'C
on the screen and it keeps comming back to this.
the lower half of the "-4." is fadded away.
Can you help me or do I need to buy a new one?
Tom Goebel
Take the battery out and put back again it will reset the whole calculator
Posted on Mar 14, 2009
I need to open my calculator hp10b
If this is an original HP model 10B or 10BII, it is held together by melted plastic studs. You will have to remove some plastic to open it and putting it back together means you will need to find another means to fasten it.
There is some advice (without pictures or video) at
Jun 28, 2015 | HP 10b Calculator
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
I wonder what is the model of the battery using on HP 10b
HP 10b Calculator requires two CR2032 Lithium batteries. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For further information you may refe to HP 10b Manual
Dont forget to appreciate the solution if I could have been of any help!
Feb 27, 2011 | HP 10b Calculator
Replace the batteries of HP 10B calculator
Make sure the calculator is turned off. Press down and outward on the battery compartment cover until it slides off. Turn the calculator over and shake the batteries out. Insert the new batteries, orienting them according to the diagram inside. Slide the cover back into the slot.
Oct 21, 2010 | HP 10b Calculator
Paper stuck and can't reach from regular opening.
support site for that model
heres a link to paper jams - about half way down is a video of how to clear paper jams, and past the video is a step by step guide
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | HP Photosmart C3180 All-In-One InkJet...
LG Phillips LP154W01 15.4'' LCD screen lower half not working
Yes, you need to replace the screen, and it has to be the exact model. LCD screens break all the time, and it's not cost effective to repair them.
Oct 14, 2009 | Compaq Computers & Internet
Hp dv5000 half screen gets stuck and blurry
It is recommended that you replace your screen.
Mar 17, 2009 | HP Pavilion dv5000t Notebook
You have a closed caption setting turned on to text. Its probably near your channel up or down button. Keep pressing it, it will cycle through text1, 2, 3, 4, cc1 and cc2 and off. When you get to off leave it for a few seconds and it should disappear.
Jul 09, 2008 | Toshiba Televison & Video
Paper jam
Fiend your solution direct from hp. Here is your solution...
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Black on lower half of screen
This type of problems and some OSD problems are occurs due to microprocessor over modulation. One option is there. That is if you have any child lock or keypad lock or frontpanel lock. First locked the system. Now check your problem arise. If it is not OK. Otherwise try to find nearby any radio frequency cable across in your tv. keep away that cablewire also. your problem solved. Even you get Call your nearst service provider..
Aug 23, 2007 | JVC AV32F577 32" TV
HP 10bII Calculator Logo
133 people viewed this question
Ben Johnson
