Question about Samsung SV5000W VHS VCR
NTSC connection with satellite
I have a LG NTSC TV that I am trying to connect to a SKY satellite dish in England. I have a SV-5000W vcr. I had it all connected last week and my wife disconnected everything to move our entertainment center and I can not get it to pick up my satellite signal anymore. I believe I have everything hooked up properly. I have an SCART cable connected to my satellite box to the TV and another SCART cable from the satellite box to the vcr. I also have an aerial line from the tv to the vcr. Right now I'm receiving a black and white picture that is rolling. I think I have an input or output signal problem somewhere. Maybe you can give some pointers.
  • Toby Stroud Jun 23, 2007
    Thanks for the help guys. I figured the problem out. I got rid of the scart cable from the TV to the VCR and added an RCA cable. Then I ran a scart from the VCR to the satellite box. Presto. I basically wasted my money buying new scart cables. But no matter the problem is fixed. Once again thanks..
  • 97 Answers
Sounds like a damaged Scart cable. Replace cable.
Posted on Jun 22, 2007
  • Kris Wingert Jun 25, 2007
    Have the tech check fopr cold joints in unit PCB. If unit was operating for all that time then shut down, this condition could have revealed itself during that time.
    President:
  • 3,130 Answers
Take the scart plug out of the sat. receiver and check and make sure none of the pins are bent. have seen this a dozen times in the past. This B&W rolling picture, is this from the sat. signal? Check the cable also with a new one or another scart cable. Good Luck
Posted on Jun 20, 2007
    Genius:
  • 1,074 Answers
Interchange the wires probably they could be broken when the movement occured.good luck
Posted on Jun 18, 2007
  • Henry  Thomas
    Henry Thomas Jun 19, 2007
    at this time my friend since interchanging the wire does not work i think it is time to call in the tech you could be having a tunner problem or IF problem.it is useless for you to try and figure out the problem.it is more technical than you think worst if you do not have the abilty to diagnoss or trouble shoot electronic components call in the tech.good luck.
SOURCE:
Just bought a Panasonic TX-P42G10B 42in 600Hz Full HD with freesat HD built in. We currently have Sky +, but i was unwilling to pay the extra a month for the sky HD service. Therefore this tv seemed fine....
Use a good quality scart leads for starters.
connect oon end to tv and the other labeled tv on sky box. The other is labeled vcr. connect another lead from vcr or dvd to that connection.
If you have a hd dvd player or Bluray, then buy a HDMI lead and connect straight to one of the HDMI inputs on the tv. I know this is late but i hope it still helps you and anybody else who may read this.
Dec 28, 2009 | Panasonic Televison & Video
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
Philips flat tv. Can't get it to hook up to dish network. The room where the tv is there isn't a dish box. We have to watch what is on in the other room. It only has one coax cable to hook up. Don't know...
I should be channel 3 or 4. This assumes that this coax cable is coming out as a TV R.F. connection of a Dish Network Box (Satellite Receiver) intended for direct connection to an old fashioned NTSC (channels 2-13, 14-83, possibly even has cable channels depending on how old?) TV.
If this coax is the output of a coax going directly to the Satellite Dish or through what might might look to you like some kind of fancy splitter (called a Multi-Switch) the you WOULD NOT want to hook that to your old NTSC tv. The frequency is too high ... etc. etc... you would need Dish Box (as you call it) a.k.a. a Satellite receiver - with a good and active satellite card from your provider.
Jul 07, 2009 | Televison & Video
When convert PAL-NTSC w/ SV-5000W to Samsung Plasma only B & W pic
Switch through the TV input selector until you find the proper input channel , probably you are using the wrong input.
Oct 28, 2008 | Samsung SV5000W VHS VCR
I have a Panasonic tv model TH 42PZ80B; a Panasinic Blu-Ray dvd model DMP-BD50; a sky box (not as yet HD) and a Sony video SLV-SE 830G. I have a Satellite dish and a normal TV aerial. In the loft I have a...
You need to try and isolate the piece of equipment which is causing the problem.
You've already tried the aerial lead direct to the TV and this is OK.
Disconnect all scart leads and try the RF on its own.
Try the Aerial lead to video, then video to TV.
Try aerial direct to Sky box, then to TV.
Try just connecting the RF out from the Sky box to the TV (no aerial input), can you tune into a good channel 68 picture from the Sky box.
Then Try the VCR to the Sky box (no aerial input), see if you can tune into the VCR and Sky channel.
Hope that helps.......
Jul 10, 2008 | Televison & Video
Connection to Dish service
Your t.v is having only RFin , and if you connecting dish receiver , normaly their are two o/p for receiver one is RF and two is for audio out and video out. if your connecting direct RFout to t.v RF in then you have to tune the t.v in all bands. if your receiver do not having RFout facility, then you have to connect AV out to converter and then RFin of t.v. if you having a vcr, then connect AVout of dish receiver to vcr AVin and then vcr RFout to t.v again tune the t.v and pwer on the vcr.
Jun 24, 2008 | JVC Televison & Video
Just bought TV and connected with red,white, yellow and s-video connections. screen says NO SIGNAL. I have a satellite dish and dvd/vcr. the dvd/vcr image shows up on tv screen.
* Possible Problem *
It's not clear how you have each of the components connected to the TV, but you do mention that you used the "yellow" and s-video connections. Those are both video connections. The yellow is a "composite video" connection. Many TVs won't accept signals from both the yellow and the s-video connections at the same time. Usually one will override the other.
* Possible Solution *
Make sure the satellite dish is on and (hopefully) on a valid channel. Try disconnecting the s-video and checking the screen. If it didn't work, remove the yellow connection and replace the s-video cable. Check again.
If the problem persists, please explain how the TV, dish and the dvd/vcr devices are connected to each other (audio cables not relevant).
May 15, 2008 | Televison & Video
Pal to NTSC
Hi, Based on your post/description, you need to get a multi-system TV to go with your multi system VCR if you are going to playback VHS tapes from different regions. You are quite correct "Plays NTSC tapes to NTSC, Will not Play Pal to NTSC" to play PAL (even Secam) you would need a PAL/Secam TV. They have a different system for color and audio. In some cases, you can still play PAL but you get it in black & white and picture squeezed from top & bottom. Hope this be of some help to you. Good luck and kind regards.
Aug 22, 2007 | Samsung SV5000W VHS VCR
Multiple video inputs
Unfortunately, you cannot use the connectors at the same time. The S-Video connector overrides the standard video connector. This is why they share common audio left/right inputs. If you could use them separately, they would each have their own set of audio inputs. (S-Video does not carry audio signals on the cable.) I'm assuming that you are connecting your Satellite as an input to your VCR, and then your VCR to the TV via a video connection. The VCR passes the satellite signal through unless you are watching a tape, then it overrides the dish signal. You have a few choices here: 1. You can connect the coaxial (RF) output from the VCR to the TV, and watch the satellite and VCR on channel 3 (or 4). You can then connect the DVD via S-Video, and watch it on "video". This is the simplest solution, and provides the best picture quality for the DVD (with this TV), but lower quality for the dish and VCR. 2. You can connect the DVD player via RF (if it supports that), watch the DVD on channel 3, and connect the VCR via video. This will make the DVD picture quality terrible. 3. You can replace the VCR with a combo DVD/VCR unit. You can then connect the S-Video out from the combo unit to the TV. This is a more expensive solution. 4. You can replace the TV with a model that includes more inputs. This is the most expensive solution, but will allow you to watch your DVD over component cables (very high quality) and VCR and dish over S-Video. Ironically, the obvious choice, connecting the DVD as an input to the VCR (as a pass-through) simply WON'T WORK. The signal put out by the DVD player is "copy protected" (using a system called MacroVision) which the VCR will refuse to play, even as a pass-though. Best of luck with this. Given that you are trying to make this all work without replacing equipment, I recommend option #1, until you decide to break down and buy a shiny new HDTV. They are coming down in price every week, but only you can decide when the time is right.
Mar 22, 2007 | Sony KV-32S26 32" TV
Samsung SV5000W VHS VCR Logo
71 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
