Question about Dell Latitude D505 Notebook
Power up problem
I have just put a new battery and the laptop powered up then i did a proper shut down but now it wont power up.i have the battery light flashing on and off.
  • 3 more comments
  • nicky3972 Jan 15, 2009
    no it wont turn on with the battery out
    no it does not power up with the battery out
    right ok cuz i had it on this morning turned it off then nothing but like i said the battery light is flashing
  • BillW50 May 11, 2010
    Ouch! Well I would reset the memory, hard drive, DVD/CD drive, etc. You can trying disconnecting one memory card at a time (if you have more than one), hard drive, etc. and see if it will at least turn on. As a device could be drawing too much current and has failed. Could be the AC power adapter is shot too.
    Does it turn on without the new battery installed?
  • 148 Answers
go to > technical support > input your service tag > search for battery issue it will tell you about the flash code you are getting on battery
further queries are welcome
Posted on Feb 17, 2009
Just wanted to confirm a few things..
Did you do a hard power down by holding the power button down for 5 seconds or by just briefly pressing the power button (which would put the computer to Sleep).
I've found this laptop occasionally does not properly recover from Sleeping under Win8, that's why I ask.
Either way, do a hard power down by holding the power button for 5 seconds.
Unplug the laptop and find the battery disconnect pinhole switch underneath (indicated with a picture of a battery lifted up) and using a paperclip press and hold for 30 seconds.
Try powering on again, do you atleast get the Acer logo appearing when powering on?
Aug 22, 2016 | Acer Computers & Internet
Samsung rv511 wont shut down properly
Pull the battery and then put it back and see what that does. My concern is that it maybe too hot. Go to and download the free program called speedfan. Run that program and it will tell you temp of the cpu and the hard drive.
Jun 30, 2016 | Samsung Rv511
Laptop wont turn on.
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
Aftermarket Car Headlights
Jun 11, 2012 | HP Pavilion dv6-1030us Notebook
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Dell Inspiron 6000 powers up, caps lock flashes 9 times, then laptop shut down. Why???
Unplug power cord from laptop, remove battery from laptop. Open memory access panel on the bottom of the laptop. Remove memory module(s) (SO-DIMM). Plug power cord back into laptop. Turn laptop on (with the memory removed), the caps lock and scroll lock LEDs light, then the laptop shuts itself off. Unplug power cord from the laptop. Reinstall the memory modules. Make sure they are seated correctly. Put the battery back in, plug the laptop back in, and power on. Laptop should power on and boot up properly.
May need to hold the power button down to get it to power on properly.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 03, 2011 | Dell Inspiron 6000 Notebook
Computer will not start up only sometimes after it sits for days but after shut dowm wont start up again
Try performing a hard reset on the laptop by removing the battery, unplugging the Power Adapter and disconnecting external devices connected to the laptop. Once everything is removed/disconnected, press and hold the power button for around 15 seconds. Put everything back then power the PC on. The reason this issue happens is because the computer doesn't shut down properly and because of this charges get left on the laptop's motherboard, holding power button down with nothing connected to the PC drains these charges. If still the same issue exists, try updating Windows, there might be updates that doesn't install completely. Update drivers as well and run a system scan with your security software.
Hope this help. Goodluck!
Mar 29, 2011 | Dell Studio 1537 Laptop
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
It wont come on just getting a flashing light on the left hand corner.
It is possible that it is having trouble recovering from sleep mode. Try holding the power button for about 10 seconds to see if it shuts off completely. If it does not, disconnect the wall power and remove the battery. Put the battery back in and start it up.
You will probably get a notice that it was not shut down properly the last time depending on the operating system, but you should be able to ignore that error.
Sep 09, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Dell Latitude D505 Notebook Logo
100 people viewed this question
Alun Cox
